1 - 4 of 4 Posts
Check Engine Light came on recently, code is P0128. It says that Coolant temperature is below Thermostat Regulating temperature. I went to OEMBimmerParts.com to buy a Thermostat replacement. However, I got two options on the site.
Cooling Thermostat OEM 11537549476
Auto Transmission Cooler Thermostat OEM 17217559962
I'm not sure of the difference between the two and which I would need.
I have provided pictures below.
It would help if you post more information. Yr ,model , Eng .. then go to realoem and get the correct part numeber for your thermostat.
It's the first picture for engine coolant . Second is a transmission cooler. .
1 - 4 of 4 Posts
