Hi,
YEAR = 1996
ENGINE = M52
E39 520i
in the last few days I noticed abnormal idle rpm "hang around" 1500 and higher, and then slowly would come to normal idle if I tapped the throttle.
That made me curious to look if the throttle cable was getting stuck from the cold/dirt friction.
I looked and in fact, the 2 throttle cables, the cruise control & throttle pedal had slipped out of the guide rails.
I slipped them back in place, sprayed teflon lubricant on the cables, including aiming into the interior of the sleeve, and went for a test ride.
No longer had a high rpm "hang around" or anything, behaviour 100% normal.
I am writing just to testify that this may happen, or that maybe it is something to look for if you get a strange high rpm that makes you feel like the cable is stuck.
I'm sure this is like nothing new.
By the way, I do use cruise control frequently, and maybe as a precaution, one should try not to mix "pedal" and "cruise control" activation and deactivation too much, maybe it could create a situation where a cable is slack, and could slip out. Even though I suppose they are meant to have independent spring pull that ought to prevent a coupling of pull-&-slack.
I now try to activate/deactivate cruise control without pressing on the throttle at the same time.
The state of these cables is now something I will add to my list of weekly checks.
Add another to the list! :roundel:
YEAR = 1996
ENGINE = M52
E39 520i
