1 - 13 of 13 Posts
Dealership says my thrust rod bushings are completely cracked.
A bit confused with all sorts of different names.. Is this the Front Control Arm, or the Lower Control Arm?
2006 530xi 6 MT
On any other car, these would be called "lower control arms". BMW calls then by several names: thrust arm, tension strut, radius rod. No matter, these are all the same thing. There is, what appears to be, a hard rubber bushing pressed into the arm. But, that hard rubber bushing is actually filled with hydraulic fluid -- a small amount. When it ruptures, you might have seen a very small puddle on the floor under the wheel of black oily stuff. It doesn't not remove easily, even from my epoxy painted floor. A ruptured bushing isn't critical to fix immediately. On the E60, that arm is aluminum and you can only replace the bushing once and then you need a new arm. If you are going to DIY, a new TRW arm off Amazon isn't much more than the bushing itself and then you don't need to press out and in the bushing.
2006 530xi 6 MT
BTW, TRW Automotive and Lemforder are both ZF companies. I suspect these are probably made in the same factories. The TRW ones I got had the BMW logo and part number ground off the arm. The ones I took off the car were TRW and I had the car since new, so these were originally TRW.
Discussion Starter #5
If I remember correctly, Front Upper Control Arm bushings can be replaced, but not the Lower Control Arm Bushing.
Was wondering which is the Thrust Rod Bushing.
I got my car serviced like couple years ago, so no one remembers except taking the car back in there.
Upper is the thrust arm. You can replace just the bushing, but it's very hard. I would not bother. Just replace the arm. I removed my bushings to install monoballs and my 20 ton press was struggling.
It makes no sense to press out the bushing and install a new one. By the time you pay for the hydraulic service, you could have easily installed a new arm with 2 new bushings or bushing/ball joint yourself. Easy DIY.
Another vote for replacing the whole arm. Mine were on their way out at 70k miles. Not too bad of a DIY job.
Do you know if the TRW arms have hydro bearings like the OE lemforders? It makes a noticeable difference in ride quality, which is the only reason I would consider lemforder over TRW.
Construction looks the same, but there is no way to tell unless you cut them open.
I didn't really care since I ripped them out 5 minutes after I got them and installed monoballs.
1 - 13 of 13 Posts
