So today I decide to spend 2 hours after work replacing my center link and tie rods..
Fail.
Hex/Torx socket on the tie rod bolt is stripped, the nut is seized and rotates the whole bolt in the ball joint.
I've ripped the rubber grease boot off, and threw some vice grips in there, they gripped into the metal but slide off when torquing the nut, nut doesn't budge.
Do you guys have any ideas? Do I need to get a saw?
Fail.
