1 - 4 of 4 Posts
I just have a leak on the right side. Is there any way to just loosen the valve cover and lift it up a bit to remove & replace the timing cover gasket?
I already did the o-rings on the vacuum pump and also the oil pressure switch.
TIA
I was wondering the same thing, if that can be done as i think that i have a leak at the left side timing cover gasket too
Just to add, i was able to take the left upper timing cover and replace the gasket without taking the valve cover out.
1 - 4 of 4 Posts
