1 - 5 of 5 Posts
Banned
People put 295/25 and 265/35 tires on wheels sized 22x9 and 22x10 AND on 22x9.5-22x11
Common sense tells me that if the wheels are wider, 22x9.5 & 22x11, then those tires should obviously be bigger. I doubt they're standard for all 22s.
Can you clarify and pls post appropriate tire sizes for 22x9.5 and 22x11
Also, if my wheels are 22x9.5 and 22x11 and I drop the car, will I be compromising anything if I put spacers? I want the dropped look and flushed with fenders. What size spacers??
Sleek Sam
What wheels did you get again?
As for the 22x9.5 and 22x11, best bet is to run 265/30/22 and 295/25/22 or 305/25/22. Just be a little cautious with the 305. Depending on wheel offset, you may have to roll the rear fenders, or run a little more negative camber then usual to make it work.
As for spacers, it depends on wheel offset, how flush you really want these wheels, and how much work you are willing to put into it.
Id say 265/30zr22 and 305/25zr22 for your setup. I just put on my hr's and im not rubbing in the back. My offset is 20 in the back
My rims are 22x9 and 22x11rear. up front I have 265 30 22 this set up is perfect.. 295 25 22 on the rear. This seems to stretch out the tire ima go with 305's next time...
Banned
Discussion Starter · #5 ·
Same wheels bro they're still being repaired.
How would I know the offset? And it's the Falken 452s I'm looking at
1 - 5 of 5 Posts
