Sorry guys. I have 225/50/17 on my car. Non staggered. I dont know if these came with the car or not but these are goodyear tires. I have done research on tirerack.com. Different brands different reviews and Im confused. Thsts why I decided to ask here. These goodyear tires are bad.... im looking for good least expensive tired that will last me a long time and are good in rain and snow as well. I have a 535xi btw. Thanks again everyone.
I also have a 535Xi with 225-50/17 tires. Bought the car new and it came with Goodyear RS-As. Replaced those with Michelin Pilot Sport All Season Plus tires but had to replace those early because the inside and outside edges wore more quickly than the tread in the middle. I maintained a consistent tire pressure of 33F / 37R (1 psi over recommended values on the door sticker).
Bought a second set of Pilot Sport AS+ tires and had a 4 wheel alignment at the dealer, but the second set did the same thing, wore more on the edges than the middle despite maintaining tire pressure. I once read a post where someone said Michelin uses different tread compound on the edges than the middle, so am wondering if that could be the reason.
When this second set wore out prematurely, I had switched to using a local independent repair shop rather than the dealer and they said my thrust bearings were bad. This was at around 75,000 miles, had those replaced, and got a 4 wheel alignment.
This time, based on the advice of the independent repair shop, I bought a set of Michelin Primacy MXM4 W speed rated all-seasons. I was not originally considering them because they are listed as Grand Touring AS rather than Ultra High Performance AS, but I like them a lot. I cannot detect any lessening of handling compared to the PS AS+. FWIW, I actually think they look better because the shoulders are more square while the PS AS+ were more rounded and gave me the impression of a skinnier tire. The tread pattern on the PS AS+ however looks more agressive.
Bruce
