1 - 1 of 1 Posts
http://mindprod.com/unmain.html
Pretty humorous read. Great how-to article on how to write unmanageable code. Some examples:
-SQL Aliasing: Alias table names to one or two letters. Better still alias them to the names of other unrelated existing tables.
-Misleading names: Make sure that every method does a little bit more (or less) than its name suggests. As a simple example, a method named isValid(x) should as a side effect convert x to binary and store the result in a database.
-Obscure film references : Use constant names like LancelotsFavouriteColour instead of blue and assign it hex value of $0204FB. The color looks identical to pure blue on the screen, and a maintenance programmer would have to work out 0204FB (or use some graphic tool) to know what it looks like. Only someone intimately familiar with Monty Python and the Holy Grail would know that Lancelot's favorite color was blue. If a maintenance programmer can't quote entire Monty Python movies from memory, he or she has no business being a programmer.
-Cd wrttn wtht vwls s mch trsr: When using abbreviations inside variable or method names, break the boredom with several variants for the same word, and even spell it out longhand once in while. This helps defeat those lazy bums who use text search to understand only some aspect of your program. Consider variant spellings as a variant on the ploy, e.g. mixing International colour, with American color and dude-speak kulerz. If you spell out names in full, there is only one possible way to spell each name. These are too easy for the maintenance programmer to remember. Because there are so many different ways to abbreviate a word, with abbreviations, you can have several different variables that all have the same apparent purpose. As an added bonus, the maintenance programmer might not even notice they are separate variables.
1 - 1 of 1 Posts
