Hello All,
I just serviced my mechatronics unit (seals, trans fluid, new solenoids) in our 2007 530xi and I'd like you to confirm a few things. I performed the same service (minus solenoids) several years ago but I cannot recall all of the specifics.
1. What is the transmission temperature supposed to be at for the final top off of fluid?
2. What is the fill plug supposed to be torqued to? Also, I saw one video where it was suggested that the o-ring on the fill plug be replaced but I don't recall our vehicle having an o-ring? I'll double check that in a minute. Is there a specific o-ring that I should use if such is required?
3. Can someone give specific details on where I go into INPA to perform the following.
a. Check Transmission Temperature.
b. Reset Adaptations. I know I select "E60" then "Transmission" but what specific gearbox do I select as there are four choices (Gearbox Control Mod GS19, Sequential Gearbox SSG, Sequential M-Gearbox, DXC Gearbox VGSG). We have an automatic transmission which allows the manual sport mode shifting of course.
c. Clear all errors.
I installed ISTA+ years ago but it's now saying I must activate it. Consequently, I cannot open it at the moment? So, I'm hoping all of the above can be performed with INPA.
Thanks,
Ralph
Thanks,
Ralph
