1 - 7 of 7 Posts
Can any one help me, i have just changed the head on my M20 engine, but like the sap i am, i got the Timing slightly off and cannot turn the crankshaft by hand. I now have to loosen the cylinder head and set TDC ....again.
My question is... can i do thins with the Torx head bolts and re-torque them or do i have to get another set? ...obviously the engine has not fired, so they haven't been exposed to heat.
:mad:
Discussion Starter · #2 ·
Is this feasable
Is it a sensible idea to do the following to not have to undo the head bolts
1-Remove the rocker arm retaining clips
2-"encourage" the rocker arms off the valves with a rubber mallet and piece of hardwood
3-rotate crank to TDC position
4-install cambelt
5-rotate crank, reposition rockers and clips on by one as per setting valve gaps
anyone think this might work??
3 pedals only!
It might, and would be worth a shot.
I don't think you can reuse the head bolts. If I understand it correctly, the issue is more about how they stretch when you torque them, rather than the effects of heat.
Will the crank not move at all? or will it just move a little back and fourth? have you taken the plugs out?
Other that cam timing or a seized crank, I can only think of:
starter motor stuck engaged with ring gear,
wrong head gasket( too small a bore in gasket, not sure if this could effect the M20?)
something dropped into cylinder...
Discussion Starter · #7 ·
Looks like it's down to the new gasket being too thin and the head being skimmed a little too much, now i need a thicker gasket.
1 - 7 of 7 Posts
