1 - 6 of 6 Posts
I have an '08 335xi E90. I'm looking at buying a set of wheels that come with 2010+ LCI TPMS sensors (OEM). Does anyone know if those sensors are compatible with my car? Thanks!
3/2007 328xi E91
IF they work on 2010 E9x they SHOULD work on your 2008 335xi E90 according to this supplier:
https://www.dormanproducts.com/p-67640-974-079.aspx?origin=keyword
It is my understanding that at 2011 model year the TPMS was changed as far as how it functioned, and the reason later Pressure Sensors won't work with 2006 - 2010 TPMS is MORE than just the 433 Hz frequency requirement.
I would try to find out the brand/supplier & part# on the wheels you are looking at, and checking with that supplier to see years applicable.
BTW, WHAT has happened to RealOEM.com -- the site has become basically UNUSABLE in the last few days -- overrun with ads & SLOOOOW.
Suggest using getBMWparts.com (which indicates SAME 2008 - 2010):
https://www.getbmwparts.com/oem-par...zMjh4aSZ5PTIwMDcmdD1iYXNlJmU9My0wbC1sNi1nYXM=
For those who need sensors, you can get the Dorman part on Amazon, but getBMWparts.com is the "Go-To" site for Genuine BMW parts.
George
Nuclear engineer
Right...the LCI TPMS sensors utilize same frequency as pre-LCI TPMS, but the protocol differs and prevents backward compatability of LCI sensor with pre-LCI receiver.
Change was in late Q3'2010. Build dates before 9/2010 use the same sensors as the MY'08-MY'10 vehicles.
1 - 6 of 6 Posts
