OK, what's the trick to get this paper gasket to seal properly? I have done it twice now, the second time I used a thin layer of RTV, seated the gasket, and torqued the bolts to 7-8 NM. I still have a leak. I do not think the pan is warped, it worked fine before I changed the fluid and filter, and I was pretty careful with it. Cleaned all the surfaces before re-installling the pan. ZF transmission, 2000 323Ci vert. Any suggestions?
