This is the code description according to ISTA+:
EGS: Ratio Monitoring, Gearshift 5-6
You should:
0- Clear the codes now.
1- Battery: how old is your Battery?
-inpa- status-IBS-PM1= take a screen shot and post here
inpa-status-IBS-PM2= take a screenshot and post here.
then charge up the battery FULLY! use any good charger if you have one. If not, you can take the battery out, have autozone charge it for few hours.
Then test drive, and then scan for codes, if codes are gone, you are due for a battery and battery registration.
If codes come back go to 2.
2- adaptation run: Perform an adaptation run as described in the procedure below.
Note: The transmission adaptation occurs only at a transmission oil temperature of 75°C or higher.
Once a transmission oil temperature of 75°C is reached, carry out the adaptation run as follows:
In drive position "D", increase vehicle speed up to 4th gear (approximately 25 mph), but do not allow a shift into 5th gear.
Allow the vehicle to then coast to a stop and keep the vehicle stationary for approximately 15 seconds with the brake pedal applied.
Next, with the vehicle stationary, change from D to N and back to D again.
Repeat steps 1 to 3 approximately 10 times.
Reference:
Code:
SI B 24 04 07
Automatic Transmission April 2007
Technical Service
SUBJECT
ZF 6HP19TU in Failsafe Mode with Fault 4F8D Stored
MODEL
E90, E91, E92 with N52K or N54 engines and the 6HP19TU automatic transmission produced from 9/01/06 up to 2/28/2007
SITUATION
The transmission goes into failsafe mode with fault code 4F8D (ratio monitoring, gearshift 5-4 – plausibility) stored in the EGS.
CAUSE
EGS software diagnostics is too sensitive.
This fault may occur during a 5-4 downshift only in vehicles with either low mileage, a replacement transmission, or after a reset of the adaptation values.
CORRECTION
On a customer complaint basis only, perform an adaptation run as described in the procedure below.
This problem is solved in series production beginning 3/01/07 with integration level E89x-07-03-510.
WARRANTY INFORMATION
Covered under the terms of the BMW New Vehicle Limited Warranty.
Defect Code
24 00 23 83 00
Labor Operation:
24 99 000
Labor Allowance:
4 FRU
WT
Test drive, scan for codes. Codes gone, you 're good to go. Codes back, go to 3.
3- Reprogram the EGS module. Too technical for you if you haven't done a single programming. have dealer re-program your transmission. test drive. codes gone, or codes back: go to 4
4- Do a research and find out your solenoid(s) for gears 5 and 6, and start your troubleshooting there! there are some good videos on youtube for troubleshooting mechatronics solenoids. find the part number for the solenoid(s) and purchase new ones., remove the mechatronics, remove the solenoids, and replace them. reset adaptations, test drive........ codes back? you need a new transmission. $7000.00. or just live with it until it completely falls apart!
good luck
