Transfer Case Actuator potential free fix!
1 reading
842K views 1.1K replies 251 participants last post by  jayram1408
#1 ·
A couple weeks ago, I got the "terrible triad" of lights (ABS, 4x4, and Brake). Recently, I got the clicking noise after turning the car off and was able to determine that it was coming from a transfer case. Using several posts from here, especially this one:
http://www.bimmerfest.com/forums/showpost.php?p=4473836&postcount=19
I bought a new transfer case actuator and installed it. Problem solved, no lights, no clicking, all better. It is not a cheap part at 720 bucks from getbmwparts.com, and 900 bucks elsewhere, so the engineer in me wanted to figure out why they were failing.
Which brings me to the purpose of this post. I disected the old actuator to find out what the heck is going on inside it. I appologize for the huge pictures, but some sort of resolution was needed to describe what I was trying to say.
What the actuator looks like when off the car:
And broken down into the pieces: Bottom right is the motor, top right is the brush assembly, top left is a guard of some sort that pops off (albeit bent and unusable once you have it off) and the bottom left is the gear assembly (we'll focus on this one)
After I popped off the oil guard piece, here is what the inside looked like, a ton of shavings and grease.
and closer:
So you can see the motor turns a worm gear which is mated to a black gear (which is made of plastic :thumbdwn:!!!) Eventually, this gear wears down like crazy and doesnt have any teeth left to grip the worm gear. This is what causes the slipping, and the error lights, and especially the clicking sound.
In this photo, you can see the change from good gear area to the bad area. The good area is on the left, and as you follow the black gear around to the right, you can see where it has been worn down from sitting all the time.
So, I went farther. I took off the black gear to see what it looked like:
Good side (what it should look like everywhere):
Bad side (Cause of the problem)
POTENTIAL SOLUTION:
So now we know what the cause is, how can we fix it? It has been (from my research) that everyone just buys a new actuator. Yes, it fixes the problem, I can vouch for that, but I don't know how many other people looked into what CAUSED the problem.
I bet you could unbolt the motor from the gear housing assembly (it is held on by 4 torx bolts that come off quite easily compared to trying to remove the actuator from the car).
Mark a location of the current position on the white plastic gear you can see in the first photo. After the motor is unbolted and removed (ONLY THE MOTOR, DONT DESTROY YOUR ACTUATOR AND TAKE THE WHOLE THING APART!!!!), turn the white plastic gear 180 degrees from its current location. This takes the bad part of the gear and puts it where it will not get used, which means that a good part is now in contact with the worm gear.
Re-insert the motor and bolt back together. This should give you, say another 65k miles (when mine failed) or so before you likely have to replace the actuator. Re-install on your transfer case, and voila! you should be good to go with only an hour or so of your time wasted instead of time and 900 bucks.
I haven't tried this, so try it at your own risk, but with pulling everything apart, it seems like a pretty safe bet, but obviously I can't be held responsible if something does go wrong.
Hope perhaps it can save someone almost a thousand dollars. I believe my logic is sound, but I look forward to your comments!
#1,040 ·
Gday all,
Been dealing with this issue for a while now. I was getting jerking and hesitation on acceleration for months, especially uphill. I was racking my brain trying to get to the issue for the whole time, driving me crazy. Yesterday, I cracked it and resolved to do something about this bloody issue when just as I pulled in the driveway, I got the triad of lights and the clicking when I turned the car off.
So I did the 180 (well kind of, when I pulled the gear off it slipped out of my hand and I lost its position! I***8217;ve managed to get it close to 180 I think but anyway) fix and reassembled the actuator, test drive and wow, the car drives beautifully now. No bucking or jerking around.... AWESOME...... Only now after a little drive I get the triad of lights but no other symptoms. When I shutdown I don***8217;t get the clicking weither.....
So a question for you lot. You think that my problem is That I didn***8217;t do the 180 precisely enough and that***8217;s what***8217;s throwing my triad up again or maybe have I another issue? I***8217;ll order a new gear online and change it out when I get it but until then I need to drive the car. With all that***8217;s going on in the world right now I fear the freight and online ordering might be slower than normal, meaning I might need to drive the car for a while the way it is..... Think it***8217;ll be ok or will I be causing damage?
Love to hear your thoughts guys.
#1,041 ·
Gday all,
So I did the 180 (well kind of, when I pulled the gear off it slipped out of my hand and I lost its position! I’ve managed to get it close to 180 I think but anyway) fix and reassembled the actuator, test drive and wow, the car drives beautifully now. No bucking or jerking around.... AWESOME...... Only now after a little drive I get the triad of lights but no other symptoms. When I shutdown I don’t get the clicking weither.....
So a question for you lot. You think that my problem is That I didn’t do the 180 precisely enough and that’s what’s throwing my triad up again or maybe have I another issue? I’ll order a new gear online and change it out when I get it but until then I need to drive the car. With all that’s going on in the world right now I fear the freight and online ordering might be slower than normal, meaning I might need to drive the car for a while the way it is..... Think it’ll be ok or will I be causing damage?
#1,042 ·
You won't be causing any damage mate. Your just driving in rear wheel drive...maybe lost of traction.
I have the notion it could be dirty corroded speed sensor. you live in muddy harsh weather area I suspect?
Moreover, first read the codes on the car's obc with a scanner specifically for bmw...cheers!
Sent from my SM-J727T using Tapatalk
#1,044 ·
Replacing the gear/motor is easier than swapping the whole transfer case, which I had to do. I have a new [to me] ECU for the transfer case, and a whole new servomotor laying on my bench after trying to sort out my issue..
Good advice on checking the codes. You may need to calibrate the servo-motor too so it knows the correct movement for that gear.
- Tim
#1,045 ·
It is "penny-wise, but pound-foolish" to go to all the work to remove (and turn/reinstall) the TC's gear, without replacing it. Especially because the part costs only US$8 to $10.
#1,046 ·
Absolutely correct however my trans was bucking and carrying on so badly something had to be done. I was concerned for my diff that's how bad it was.
New gear in hand, about to install tomorrow but one last question for you wise asses out there.
What kind of grease are you all using to live this bad boy up? Think it matters? (So Long as it's compatible with nylon..... obvs)
#1,050 ·
I think I used white lithium. Clean out the old grease beforehand.
#1,054 ·
So..... today I replaced the kaput actuator year with a new one that I purchased off eBay.....
Now my transmission is bucking like a bronco!! No error loads or trio of abs, park brake and 4x4 anymore but I’d prefer those to this jerky transmission I have again!
I’m wondering if my gear that I bought isn’t close enough to spec and is causing problems.....
#1,057 ·
If anyone is looking to do this, I'll have a gear for sale soon. I bought what I needed, then the X3 was totaled before I could perform the maintenance.
I have few other sale too...
#1,059 ·
Considering that this was the first repair I've probably ever done in my life. It was... fairly smooth. I did feel some youtube videos gave a false sense of how much space you have underneath on an x3. There was one E10 screw on the transfer case actuator that had a very tight space to work. A universal joint + socket was all that could fit in that space. But it did help immensely, as well as just changing the angle I attacked it from. I opted for a cheapo replacement actuator instead of fixing the gear, but now I have more time to replace the gear on the original part and can still drive my car. It even cleared up all my dash lights so no need to reset anything. Been working great!
Thanks for all the people posting about their experiences here. I had just spent like $700 having a shop replace my starter, so saved a bunch on this repair felt good.
#1,060 ·
If anyone is looking for these parts, I can make them a deal. I bought everything and before I was able to do the preventative maintenance, my daughter's '06 was totaled.
Feel free to PM me anytime.
  • Like
Reactions: dukedkt442
#1,061 ·
I have a question relating to this, I recently changed the transfer case actuator myself as recently when I would drive and take certain turns my 4x4 light would blink like crazy and my car would shift like as if it was slipping, and not soon after randomly my ABS, Brake and 4x4 turned on as well though I didn't listen for the clicking noise. Either way after a lot of reading I took upon the task and changed the actuator and figured I should change the transfer case fluid as well since I'm the 3rd owner of the vehicle now and I'm not sure when the last time it was touched (If EVER) So I went to the dealer and bought their specific transfer case fluid for my X3 which only takes 1 quart after changing the fluid and replacing the part. Now my 4x4, ABS And Brake light are permanently on and I really don't know why? Car does feel heavier than usual now anything I can maybe do?
#1,064 ·
Adding notes. I used Ravenol TF0870, with good reviews. Performance horrible. Bad vibration in acceleration above 50 mph. Cured by pulling fuse 26 (2006.03 chassis)
Either fluid is out of spec or the new actuator has killed the almost dead TC.
Stay tuned to these pages
My E83 has had Ravenol TF0870 in it for about 30K miles with no issues. I will be changing it out soon with Shell S-Tech, which is what I've been using recently.
AM.
#1,070 ·
My turn for the stripped actuator gear. Fortunately, I preemptively ordered one and had it on hand for this day. Not a bad job... I just jacked up the driver's side, pulled the four support bolts, pulled the actuator bolts and it was out in no time. I had to remove the motor from the unit to get the gear out as it was all buggered-up. Will test it out tomorrow, but hopefully it's good for another 148k miles.
AM.
#1,071 ·
They have for a few years now sold a aftermarket steel worm gear and round gear combo. These are both made of metal to eliminate having to replace it again. I have done a few now. There pretty easy and you don't even have to take the transfer case out to get the actuator off of it. Unless they have done some damage to the clutch packs which I swear are the same ones off a Harley Davidson clutch assembly. The friction discs anyways. Critical part is to make sure you get the concave thrust washer installed right or you will have problems. It's a pretty easy straightforward transfer case that uses the actuator to actually engage/disengage the amount of slip between forward and rear tires. It basically just let's the front tires engage and that's why if they fail you only have rear wheel drive. Side note, some models may need the transfer case module coded to the ecm.
