1 - 2 of 2 Posts
I have a 2013 X3 2.8L with 126K miles. Put a new engine in at 102K miles. Now the transmission appears to have a sporadic backlash when coming to a stop. Otherwise, the transmission shifts perfectly.. Has anyone had this issue? Not sure if I should start by changing the oil pan whereby the filter is built in and the fluid.
Yes - starting at about 65,000 and still happening occasionally at 79,000. It only seems to happen under certain conditions - hot weather after a long run at high speed, followed by city crawl. No faults found by BMW service or independent when examined, so no "cure" offered either.
1 - 2 of 2 Posts
