Hi All,
I in a bad need for an advise on a transmission, my transmission had a noise for the last month but only when not moving but in gear, the noise sounded like if it was coming from the muffler.Tow day ago the car lost power while driving and cam to a stop then shaked vigorously (CEL) then I got them Transmission fail safe prog. I drove it back home going on a slow speed. I thought it was the battery (since my window did not open a day ago but worked again and the moon roof open instead of closing one time and my right rear turn signal fails sometimes to work) so I went ahead and replaced the battery with a new one, the transmission worked right away but only for one spin in the parking then went back to fail safe . So I added some ATF but did not help. Finally I drove it to a BMW specialist but he said that it slips very bad no transmission error codes were fond and the conclusion was bad transmission ? I do not understand how he could not find any Errors. I did the battery disconnect fro an hour and the gas pedal tans reset and it reset bu the car does not move at all till it goes into fail safe again, The car will go in reverse normal. Please advise. Thank you.
