transmission fluid leak
573 views 5 replies 5 participants last post by  keeton
#1 ·
Hi, i have a 2006 Z4 and this winter while stored it leaked about 2 tablespoons of fluid. My mechanic topped it off and said he thought i had a small leak around the rear drive shaft and might need a seal. About 260 miles later my check enfine light comes on with the transmission indicator. BMW want $230 to hook it up and check it out. No driving issues but i also do not want to do anything to damage my transmission, The car has about 47,000 miles.
thoughts?
#2 · (Edited)
In old vehicles, if the automatic transmission sits for awhile without use (e.g., 3+ months), the seals get hard and leak. This exact leak has happened twice on my restomod with a Ford C4 automatic transmission (sat due to mods being installed). Researched and found ATP Automotive AT-205, used it the first time and it worked like a charm So I used it again the second time (about three years later). It supposedly freshens up seals (flexibility). My leak was around the shift controlling shaft out the side.
As to the idiot light, I assume it’s because the fluid level is low, but you should get it read. A local independent shop should read it for a lot less. Some auto parts shops read codes but may not be able to read BMW codes. You could buy or download a BMW code reader. Good luck!
#5 ·
plus a BMW specific scanner will allow you to read ALL the modules of your BMW car, OBDII readers will only allow you to access the DME (engine) and the EGS in some cases (transmission). if you plan to stay in the BMW ownership world, you will need the scanner, and you only have to pay for it once.
#6 ·
The most common cause of leaks with the ZF 6HP transmission is the mechatronics sleeve. Most of them failed early and under warranty but for those of us with ultra low mile cars, the leak comes after the warranty has expired. The fix is not that involved except you have to drop the (non-reusable) transmission pan to get to it. Figure on just under $1,000 from an independent and about $1,500 at the dealer. The parts are sold online as a kit (pan, bolts, fluid, sleeve) if you think you can fix it yourself.
Oh yeah, like the others said, get a BMW specific scanner.
