1 - 1 of 1 Posts
So I did a fluid and filter change on my car. But the filter I had was the wrong one so was the seal. So I put the pan back up and add new fuild with the same old seal and add new bolts thinking i will be fine. So when I look under my car the next day there big puddles of fuild that I am losing so I get under the car and check where I am leaking from and dam it. its my transmission pan so i can see where the leak is coming from I tried to tight that one bolt some more and it striped so I put another bolt in and that one striped. So now I am worried beacuse i dont know how thoese bolts could of striped When i could remove them by hand. Should i just drop the pan down again try to get the right seal and put some gasket sealant and put the pan back up. I dont know what to do and need ur guys help.
1 - 1 of 1 Posts
