1 - 7 of 7 Posts
Ones again I'm back so I did my trans filter and sleeve seal and the other seal that's Square forgot the name I updated my e61 and I'm still getting the jerk when I come to a stop I was trying to avoid buying a torque converter but from the looks of it I have no choice any idea on what else can it be
Discussion Starter #3
Non at all no check engine light and I notice when I'm driven and try to step on it the car hesitates feels like it jerks a lil
Could be TC! I would also look at changing the bushes on the main shaft and changing the solenoids and valve body seals!
Transmission
In my experience, draining the oil is normally the start of most problems. With gravity all the filings and debris end up in the valve body and solenoids and just causes more issues. Pull the box and have it checked and dyno tested.
Discussion Starter #7
Good news guys I just did the torque converter and been using the car for 2 days and I think is fix for now no jerking and a smooth shift
1 - 7 of 7 Posts
