Well, I'm retrofitting Sirius into my 2001 325i sedan. Note: BMW has a new Sirius receiver model. This model has a single antenna connection for the newer style Sirius antennas. The part # is 65 12 0 398 140. I bought a Terk SIR-MINI and installed it to the rear deck of the trunk lid instead of outside the car (yuk).
I started by purchasing a 2004 OEM cd player from a member who'd upgraded to NAV. I bought the $12 antenna adapter, and installed it a-OK... NOTE: I have the trunk mount IceLink kit, so I just bought this adapter cable from Dension that supposedly just allows the icelink to plug into the Sirius unit for power / connectivity...
Anyhow, after I connected the Head unit, I tested to make sure everything was working.. The mode button successfully switched between Radio / CD / AUX (I wired the aux input into the center console while I had the dash apart) / and my iPod. Excellent start...
So... I turn the car off (didn’t disconnect the battery), and unplug the connections from the back of the CD changer control. I then plug the extension Tom at Dension sent me from the cd changer plug to the corresponding port on the Sirius receiver. I unplugged the 2 wires from the old IceLink piece and toss the piece.. I dont think its needed... Those two plugs fit nicely into the Sirius unit...
So, all connections look good... Turn the key to position 1 as instructed and hit Mode... Nothing... My receiver doesn't say Sirius... After fiddling with the connections and having the same results, I decide to unhook the Sirius receiver and just hook the IceLink back up...
Now the IceLink doesnt work either! Ugh... Hitting Mode now just toggles between the CD player / AUX and radio.. Ugh...
I checked the fuse box, and I didnt see any fuses blown out...
Whats going on. Help?!
