Tryring to code SLI on G01. Working coding methods?
1.7K views 9 replies 3 participants last post by  shawnsheridan
#1 ·
Hey people,
Yes, I am still trying to code SLI on my G01. Most of it is done, the FSC code is in but stuck at trying to code KAFAS4.
I was able to inject the FSC code using Esys but unfortunately I could not use Esys to do FDL coding because I can not see directory names (only dots)..
I was able to enter most of the code using Bimmercode but it does not have Expert programming for KAFAS4 on G01.
So I am back to Esys. I was told I see dots on my directories because I am not using Esys Launcher. I run the Esys direct (3.40.1) and use the latest PsdzData.
Is there a working combination of Esys with a launcher at this point? If so, could someone help me with the installation?
Or, do I have to purchase the BimmerUtility?
Thanks,
Ozzie
#6 ·
It is not an E-Sys issue, it is a PSdZData issue, which requires a CAFD Mapping solution. LauncherPRO is no longer available, and even it was, the CAFD Mapping Database has not been updated in many years.
  • Like
Reactions: Jorbabcnman
