1 - 5 of 5 Posts
Hi all,
Had the window down today for what feels like first time in eternity however I noticed that when I accelerate I can hear what Ithink is the turbo whistling. I have a 2004 3.0d X5 sport.
Any ideas if this is and should it whistle when I accelerate??????
Cheers
J:thumbup:
A whistle sound on a diesel turbo is not normal. If you are hearing excessive noise from the turbo then is likely to be an air leak. A good way to find air leaks is to get a spray bottle with a fine mist spray. Run the engine and spray around all the connections one at a time with water. You will hear the air sucking or blowing out or a change in the way the engine runs . And no the water will not damage the engine or turbo.
1 - 5 of 5 Posts
