Is there any way to turn off auto start/stop or make it default to off? Thanks in advance. Car is a 2021 M760i.
There's a retrofit in ISTA, but it requires a code. That'd likely be the best solution since updates wouldn't remove the retrofit. There's also a retrofit to make the vent fan full auto, which doesn't require a code.Is there any way to turn off auto start/stop or make it default to off? Thanks in advance. Car is a 2021 M760i.
BMW is moving to secure coding (even in older cars), which is why I had suggested ISTA and going the official route (since there's one available). I can confirm the VO coding I've done in E-Sys has synced with BMW's servers once I connect with my TIS account, but standalone CAFD configuration changes from E-Sys (or anything else) do not.Since the latest update on my Z4 I can no longer disable the auto stop/start feature. Has anyone found a work around here?
No, I haven't personally been too interested in the memory feature so haven't felt like spending an evening testing it out. I was just going to have the dealer do it next time I'm in and if they can't, was going to purchase the code online through other channels to use ISTA.Did you add the option code OMSA to your G12 and it worked? For a couple years, dealers could do that as mentioned in SI B12 15 12 until BMW ended that program.
S15A actually covers a lot of models, but Secure Coding has already been introduced to selective modules within S15A, S15C, S18A, U006 and a few others. I believe the first ISTA release was 4.39.x, so it's a fairly new rollout. It's probably safer to assume when not if. The new vehicles are nearly totally locked down.Hopefully not, especially since S15A is pretty old by now!
