Hello all!
I am a new user on Bimmerfest, but I lurked a couple of times in the past few months. I now have a problem that seems related to this post. Today, I noticed a warning bulb sign. So I went around the car to check which one was burnt, but all of them were fine. Then, I noticed the driver side HID beam flickering on and off. I went back in the car, turned the parking/headlight selector switch to "ON" (it is always on "Auto") and went to check again, still flickering. So I went back in the car, checked out the warning signs.. Wow! Low beam, high beam, warning bulb, clock to zero warnings all alternating!
I shut everything off and came to check this forum. Here are the codes I could get from the procedure I found here.
115
117
118
119
120
121
130
132
134
136
138
375
167
All for the lights, except for the 167 (clock). From what I read, it could be a ground problem I guess..?
Now, I also noticed water stains on the front A pillar (passenger side). This water leak happened on my 2003 330xi also, in this case it came from the sunroof. Could water have leaked inside the fusebox and caused all these failures?
I didn't dismantle anything yet, I'll wait for your input.
Marc Fillion
Ste-Barbe, QC, Canada
