21 - 40 of 68 Posts
That is 100% correct. You need to find the line that corresponds to your TV module. You can tell this using its diagnostics address. For example the HU is 0x63 and DME IS 0x12. I forget what the TV MODUL is but you can see it on the TAL Calculation page next to the ECU.
Edit:
Looks like 4b.
Discussion starter · #22 ·
Edit:
Looks like 4b.
Got it. But can only find bl flash, not cafd and swfl?
Sendt fra min SM-G991B med Tapatalk
Choose BLFLASH, SWDEPLOY AND CDDEPLOY. They are SWFL and CAFD.
Discussion starter · #24 ·
Cool, thanks.
Ok, this is for the slow kid (me).
I Edit in talfilter to force flash the TV module.
Tal calculation- read fa - activate fa - load the edited svt ( or read ecu?) - complete flash - choose i step shipment - calculate - hw I'd from svtactual ? - calculate TAL- expert mode - load tal - load svt target - read fa (vcm) - check software- hope tv module appears and flash with fingers crossed [emoji1696]?
So once you have calculated the SVT target/update (sol) that file never changes, it is what it is. Read FA, read ECU. Load the file you just made in the section for edited TAL on the tal calculation window. You will now see a new symbol next to TV module once loaded. Calculate TAL again on this page, save, press execute and you will now see TV MODULE in TAL processing.
Discussion starter · #26 ·
Just to clarify, the file i open in talfilter editor, is that the svt actual file I get from read ecu?
Sorry all the questions, but this editing stuff is just a tad new to new (I have only coded and flashed the normal way before)
The SVT ACTUAL mate. The target is irrelevant for this process so leave it calculated and unchanged. You’ve already edited the file as you showed in the pictures. Try not to over complicate this. All you’re doing is taking the SVT actual, telling esys that a specific module MUST be included in the TAL based on the changes you made. It’s all simple logic.
Discussion starter · #28 ·
Haha, you are right.
But i often just press the buttons because I know that is how it works, but really I don't know what each step does/mean.
I will give a go again, and hopes the flashing doesn't fail. I hate it when it goes to transport mode with alle the errors. It takes forever do delete in ista with a slow enet cable.
That’s the thing, most people just press this and that with no idea what the functions are actually doing.
Show me your TAL processing window before you start, or, if the flash has started you can monitor the progress for each part of the SVK by expanding the window up on TAL Processing.
Discussion starter · #30 ·
I am messing something up in this step.
It is in TAL filter I load the edited svt actual right ?
I have calculated target as well right ?
There is NO NEED to edit the SVT ACTUAL. Load the SVT ACTUAL in the tal filter editor. Make the changes and save. Now go to tal calculation page and load the file you just saved in the section below the SVT target. Now click calculate TAL, execute. It’s just logic mate. You are loading the edited TAL file into the tal calculation page to force the changes.
Discussion starter · #32 ·
Yeah but when I calculate TAL there is 2 error boxes. If I ignore at press execute and only mark tv tv module and check for software I am missing files
Your tal processing is very wrong if you have HWINSTALL OR HWDEINSTALL in the TAL. Check you ilevel shipment date.
Ok, then you need to workout why you have RED ECUs in the SVT tree. There should NOT be HWDEINSTALL/HWINSTALL in the TAL.
Any ECUs with missing SWE should be deleted from the TAL to make life easier.
Discussion starter · #37 ·
Yeah. I guess it is out of my league then.
But thanks for trying. Really appreciate it.
I will se if I can find a guy locally who can sorted for me. I guess it is kinda simple, you just need to know what you are doing, which I don't:)
I can do it remotely mate, won’t take me long. I was trying to empower you :)
Send me your AnyDesk details in PM
  • Like
Reactions: Sixaxisbuild
21 - 40 of 68 Posts
