1 - 6 of 6 Posts
I was changing the clutch and my luk clutch kit came with two pilot bearings I've installed both ill show you guys a picture. Please let me know if I have to remove one. One went in the middle of the crankshaft and the other in the middle of the flywheel.
Automotive tire Font Rim Circle Automotive wheel system
You should only install one. If I'm not mistaken the difference between them is one is for the early 5-spd trans and the other is for the later 6-spd.
Use the one that fits on the input shaft of your trans and throw the other in the trash.
Lost but making good time
3er + 3er + 4er = 10er, Bimmers?!
Problem is I already closed it with both installed, ....
Which means, unfortunately, that you have to open it up again to set it right.
  • Like
Reactions: dukedkt442
Discussion Starter · #6 ·
What would happen if I left both in? Originally there was only the one in the flywheel, while putting everything back together I didn’t c it then realized that it’s inside the flywheel. If the one in the flywheel isn’t suppose to move back and forth shouldn’t it be ok if there is one behind it?
1 - 6 of 6 Posts
