ANother victim to the alignment issue. :thumbdwn: (to bimmer)
I had much experience with this and I have to ask you first, what do you mean they "over corrected" it? You mean they over aligned it or something or how did they over fix it?
You do not have to pay for anything, they will have to resolve your issue. First they will do the tire pressure BS and then give you a run around on how it doesn't need alignment. If you have nice wheels(and the dealer service dept. sucks) they will scratch your rims - it happened to me.
Also, you have to consider how bad the pull is because if you have large diameter wheels and tires they will tend to follow the grooves on road surfaces.
ANother thing to check lastly is the mount and balance of the tires - some cases require the tires to be rebalanced on the wheel.
Cliff330i said:
I gave the dealership and opportunity to fix it. They over corrected and now it pulls to the other side and the wheel is still off center. Are they going to tell me that I have to pay for an alignment? I have noticed on some previous threads that people have to pay for it because it's considered a wear and tear thing. In addition, I hesitate to keep having this thing alligned because I have heard somewhere that doing this alignment process repeatedly can cause it to go out of alignement as you drive.
