Hi Everyone, Hoping that someone can help me with my issue adding new TMS modules in ISTA+. I have a 2012 F10, earlier this year moisture in my headlights caused the TMS modules to a fault, I purchased new aftermarket modules and installed them. I connected ISTA+ , run vehicle test and see the message to "Initialise new headlight driver module and teach in turn indicator (ABL-DIT-AS6300_TMS_INIT)". I run the procedure and keep getting the error "The communication with the control unit FRM has been dis-rupted. The control unit must be connected. The ignition must beswitched on or the PAD mode activated".
Below is what appears in the opertions report. Any ideas on what I could be doing wrong or need to change to add the new TMS modules?
[TD]2 Minutes 46.42 Seconds (28.12.2021 19:26:50.422 ... 19:29:36.840 )[/TD]
[/TD]
[/TD]
[/TD]
[TD] [TD]Duration |
[TD]Calling up by[/TD]
[TD]TestPlan[/TD]
[TD]TestPlan[/TD]
[TD]Ended by[/TD]
[TD]NormalTermination[/TD]
[TD]Procedure step |
[TD]
[/TD]
[TD]
[/TD]
[TD]Message[/TD]
[TD][/TD]
[TD][/TD]
[TD]Duration: 0 Minutes 36.09 Seconds (19:28:59.080 ... 19:29:35.176 )[/TD]
[TD][/TD]
[TD][/TD]
[TD]The communication between the FRM and the headlight driver modules (TMS) is not OK. Continue troubleshooting with following test module in testing schedule:Headlight driver module [/TD]
[TD][/TD]
[TD][/TD]
[TD]User entry[/TD]
[TD]True[/TD]
[TD]True[/TD]
[TD][/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]Message[/TD]
[TD][/TD]
[TD][/TD]
[TD]Duration: 0 Minutes 1.34 Seconds (19:29:35.181 ... 19:29:36.525 )[/TD]
[TD][/TD]
[TD][/TD]
[TD]Service function finished[/TD]
[TD][/TD]
[TD][/TD]
