1 - 1 of 1 Posts
Hi,
I am having trouble trying to make the keyless entry happen on my 1997 523i. I am currently having to unlock the door manually. Here is what i have tried:
I have tried turning the key to position 1 then off within 5 seconds, holding unlock then pressing lock 3 times fast then releasing but the locks wont cycle to show it has worked. the LED on the key flashes constantly for 10 seconds but nothing happens.
I have tried that same process then finishing with key in ignition back to position 1 again, still nothing.
I have tried to position 1 then off fast 5 times then the unlock and lock 3 times combination, nope, still nothing.
I have tried the instructions for the IR key where you point it at the rear view mirror and push one of the buttons, but this doesn't work either.
I have scoured for different types of instructions and tried all i have found to no avail.
Fuse 53 hasn't blown, all locks and gas tank actuator are working fine, its just the remote keyless entry that isnt working. It last worked a couple of days ago, then suddenly stopped.
Please note: it is a 2 button key, i believe IR key, not diamond shaped, same shape as the 3 button boot key but with no boot button. Batteries are fine as LEDs on the key are strong.
Key image:
http://www.thecarkeydoctor.co.nz/images/bmw_ir_remote_key.jpg
Any help greatly appreciated! Please and Thank You _sl_
1 - 1 of 1 Posts
