I apologize in advance if someone has already made a thread about this, but I could not find anything that would fix my issue.
A while ago in the summer, my fans were only blowing heat, and I could not change the speed of the fans, turn them off, or change the temperature.
Eventually, the screen on the climate control unit shut off, but the buttons were still lighting up. The fans started running for 15 minutes after any door on the car was opened. A few days later, the fans would run until my battery is dead. I read up some forums, and it seemed like the FSU was the problem. So I ordered a new one, and kept the old one unplugged until the new FSU arrived.
When the FSU arrived, I installed it, but the fans just kicked right on, and started blowing without the car being on. I unplugged it, and tried something else.
I read that it could be the ambient temperature sensor under the front bumper of the car. I replaced that, plugged in the FSU, no luck. The fans did the same as before, and no display on the climate control unit.
I visually checked all the fuses in the glove box and trunk. None were bad (visually).
I went as far as replacing the climate control unit, no luck.
BUT THIS TIME when I plugged in the FSU after replacing the climate control unit, the fans did not turn on at all. I still do not get a display on the climate control unit, but the buttons light up.
I have absolutely no idea what to do now, and the nearest shop that works on BMW's is hours away. I need this car for work. If anyone has any ideas, I would appreciate it more than you could imagine. I still have heated seats and heated steering wheel, but its still chilly here in Pennsylvania
