First of all hello! This is my first post, and I'm quite new to the whole Bmw scene..
Anywho, I have been driving my 2003 540i Auto around for about 4 months now.. I've had absolutely no problems at all until recently..
When I'm driving the automatic transmission in "manual" mode, it changes fine and it's smooth and all, but occasionally drops back a gear and then won't let me change up past the current gear it is in.. I can see the gear number on the cluster change up a gear, but then it drops back down to the previous number..
So for example, I'm driving along and shift from 3rd to 4th, it will drive in 4th for a tiny bit but then it will drop back to 3rd.. Still allowing me to change 1st, 2nd, 3rd.. But not letting me go into 4th or 5th..
It has also done this at separate times for both 2nd and 3rd gear..
Also I get zero warnings like fail safe mode or anything..
What I do at the moment is I pull the car over, disconnect the battery for 2 or 3 minutes and when I start it back up its fine.. For a few days, until I decide to use "manual" again..
Now I don't believe it is a fluid problem because I had the fluid replaced about 2 weeks ago.. Unless they didn't do it right or something but I have faith that that isn't the problem..
The whole fix with disconnecting the battery makes me think it's some sort of a computer problem..
Thanks a bunch dudes!!
