1 - 4 of 4 Posts
I just recently bought a 93 325i (auto tranny). It has 130,000 mi. I want to make it fast but i don't know where to start. I was thinking of buying an m3 exhaust (my muffler went out), a Dinan cold air intake, Dinan Transmission Chip, and a Dinan Engine chip. If anyone has any suggestions to what i should do, i would really appreciate it. Also, if anybody is selling anyone of these items, pls let me know. I am also looking for a good deal on 17" AC Schnitzer type II's and was considering a 5 or 6 spd transmission. Does anybody know how much the transmission would cost me including labor?
..snip..
[/QUOTE]
I have an early e36 also, the same as your car but stick. Unfortunately it seems the mufflers have a propensity for rotting, and I suspect getting the oem muffler will result in the same :cry: I went and purchased an aftermarket stainless muffler but it ended up being too loud, but otherwise satisfactory. :thumbdwn: Installation, in my case, was uneventful -- but the exhaust may need to be replaced all the way to the catalytic converter :thumbdwn:
By the way, are your front door panels loose? A common problem with the first two model years or so -- I tried bolting the panels to the frame but the doors are still easy to snap off.
Jordan
Discussion Starter · #3 ·
Yes, my door panels are also loose. Actually, one of my back ones is extremely loose. Also, yesterday my window wouldn't go up. I think its just not aligned because it was very loose. Do you know why this could be?
That could be, though I haven't had that happen to me! :angel:
The doors have a good number of plastic relays; the driver's door regulator for central locking burnt out on mine shortly before I purchased my car (August 2001). The doors would make a whirring noise and a clunk and then not open until I jiggled the key in the lock. Turns out if the relays fail to act exactly in sync the doors will not open :mad: I'd post a photo of the relay but I threw it out :(
As a heads-up, here are some other potential glitches to keep an eye out for as your e36 ages:
The dashboard electrics get kinda schizo. My temperature gauge, parking brake light, oilservice meter, and a few other idiot lights are busted. I just ignore these gauges. If the car begins to roll, I'll know it! :yikes: :yikes: Always use an oil change sticker rather than rely on the little oilchange gizmo.
Body moulding gets undone a bit.
I blew a left rear wheel bearing and failed inspection. :thumbdwn: That can happen to any old car, so that's not a glitch, just age.
That's about it for right now. I can't comment on the automatic, but the manual is quite stable (save for a tiny bit of scratchiness on the 2nd synchro, but the car is almost ten, so I cut him a break.)
Good luck,
Jordan
1 - 4 of 4 Posts
