UPDATE: So I thought the problem was coolant leak from the thermostat. Drops of white coolant residue still coming back. May be the two plastic coolant pipes under the intake manifold....still troubleshooting.
2000 528i
I notice a white residue on my air box and power steering reservoir after driving (bottom photos). I found what I think was the source in a spot on the underside of the upper rad hose connection and so I replaced the thermostat with a Wahler (it was a Motorad before). I am assuming that coolant is coming out of the rad hose when it's hot and spreading. The upper rad hose was already new from a BMW dealer ( a few months old). After replacing the thermostat and refilling with BMW coolant and purging the air the white spray has returned again after driving. Should I return the hose to the dealer? I have not see this before.
2000 528i
