1 - 6 of 6 Posts
Hello every one
i need your support yesterday i was just start using ista - p and i was think to code for aux for my car BMW E66 and adding AUX.
i found some of things there like NAV and 2 more device replaced and i know for that so i add some features like auto lock when car move etc.. and also battery was replaced so i try to fix all this things after finish every thing goon from car no VIN idrive no thing work also dashboard etc.. i try to check again i didn't find vehicle order i dont know what to do any idea how i can fix this
please any idea let me know car in my home cant go any where.
Discussion Starter · #2 ·
hello everyone
any one can help please
i have k-dcan and ista-p and when i try to connect car cant find VIN number i put vin number moving next step said Vehicle order missing while i try get vo online no thing happing
i was checking i found in logs some details like code and cas etc... all car equpment in logs its like xml i will share maybe it can help
<?xml version="1.0" encoding="utf-8" ?>
- <SG-LIST xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="BN2000.xsd">
<VehicleData VIN_17="WBAHN21057DS87656" />
  • <SG SG_NAME="CAS" SG_GROUP_NAME="D_CAS" BUS_TYPE="SYSTEM_BUS" VEHICLE_WIRING_SYSTEM="BN2000_1_PHASE" SG_HW_NUMBER="" SG_SERIAL_NUMBER="000000001" SG_PROGRAM_REFERENCE="0041TIDF459S" SG_DATA_REFERENCE="" SG_HARDWARE_REFERENCE="0041TID" SG_MAX_BLOCK_LENGTH="64" MEMORY_AREA_ADRESS="000000" BMW_NR_OFFSET="36" ZUS_BAU_NR_OFFSET="42" SG_FLASH_TIMING="0A0A0A" SG_AUTHENTICATION_RANDOM_NUMBER="" START_COMMUNICATION_RESPONSE="0000" INDEX_OF_CODING_DATA="6668" BUILD_I_LEVEL="E065-06-03-500" HISTORIC_I_LEVEL="0" CURRENT_I_LEVEL="E065-15-07-500" GATEWAY_OF_BUSES="K-CAN P">
  • <BUSES primaryBus="K-CAN S">
<BUS name="K-CAN S" id="VEHICLE_BUS_3" topology="Bus" />
<BUS name="K-CAN P" id="VEHICLE_BUS_8" topology="Bus" />
</BUSES>
<SG_EXTRA_DATA VIN_17="WBAHN21057DS87656" CAS_CODING_DATA_1="156601011e03e2" CAS_CODING_DATA_2="3036383848354154" />
- <SG_VEHICLE_ORDER>
<TYPE>HN21</TYPE>
<TIME-CRITERIA>0306</TIME-CRITERIA>
<PAINT-CODE>0475</PAINT-CODE>
<CUSHION-CODE>U6NB</CUSHION-CODE>
- <SAS-LIST>
<SAS>220</SAS>
<SAS>261</SAS>
<SAS>2BK</SAS>
<SAS>358</SAS>
<SAS>403</SAS>
<SAS>415</SAS>
<SAS>416</SAS>
<SAS>423</SAS>
<SAS>428</SAS>
<SAS>430</SAS>
<SAS>431</SAS>
<SAS>437</SAS>
<SAS>441</SAS>
<SAS>442</SAS>
<SAS>459</SAS>
<SAS>508</SAS>
<SAS>521</SAS>
<SAS>524</SAS>
<SAS>534</SAS>
<SAS>548</SAS>
<SAS>5AC</SAS>
<SAS>601</SAS>
<SAS>609</SAS>
<SAS>633</SAS>
<SAS>672</SAS>
<SAS>691</SAS>
<SAS>698</SAS>
<SAS>822</SAS>
<SAS>823</SAS>
<SAS>845</SAS>
<SAS>850</SAS>
<SAS>853</SAS>
<SAS>861</SAS>
<SAS>864</SAS>
<SAS>880</SAS>
<SAS>887</SAS>
<SAS>8SM</SAS>
<SAS>8SX</SAS>
<SAS>925</SAS>
<SAS>956</SAS>
<SAS>983</SAS>
<SAS>9AA</SAS>
</SAS-LIST>
<UNITS />
- <E-WORDS>
<E-WORD>LEDE</E-WORD>
</E-WORDS>
<HO-WORDS />
<MODEL-SERIES>100101010110010110111111</MODEL-SERIES>
</SG_VEHICLE_ORDER>
<SG_CODING_DATA_SET CODING_DATA_00="aff41ec8140a283264320e1000" CODING_DATA_01="0261200001001002180000000000000000 00000000000000" CODING_DATA_02="2400307f00000032015e0032015e119400 fa00960032012c00c803e80a00" CODING_DATA_03="4403140808782800020000" CODING_DATA_04="5005050a020000000a6400" CODING_DATA_05="170a051c" CODING_DATA_06="0100" CODING_DATA_07="" CODING_DATA_08="" CODING_DATA_09="" CODING_DATA_0A="" CODING_DATA_0B="" CODING_DATA_0C="" CODING_DATA_10="" CODING_DATA_11="" CODING_DATA_12="" />
<SG_CODING_DATA_SET_31 CODING_DATA_00="00000000000000000000000000000000" CODING_DATA_01="00000000000000000000000000000000" CODING_DATA_02="00000000000000000000000000000000" CODING_DATA_03="00000000000000000000000000000000" CODING_DATA_04="00000000000000000000000000000000" CODING_DATA_05="" CODING_DATA_06="" CODING_DATA_07="" CODING_DATA_08="" CODING_DATA_09="" CODING_DATA_0A="" CODING_DATA_0B="" CODING_DATA_0C="" />
<SG_CODING_DATA_SET_34 CODING_DATA_00="F3CFE61FFFCFE61F0A10401401200000" CODING_DATA_01="FFCFE707020010000000000000000000" CODING_DATA_02="56473033990700000120200000000000" CODING_DATA_03="2801020E006432000000000000000000" CODING_DATA_04="04788F3F9B11EE8030FC770000008000" CODING_DATA_05="9511089F2A280C280C00000000000000" CODING_DATA_06="FC72EE20FCFC402372234020FCFC2072" CODING_DATA_07="2020F300E00105040ABB3F1A3580C105" CODING_DATA_08="BBB8B5584300FFED4A00000000000000" CODING_DATA_09="FCFC40214021407372012B6924400000" CODING_DATA_0A="FA277FD79A860A0A56140437C0888888" CODING_DATA_0B="88715E51473F362F2F2F2F2F2F2F9B6D" CODING_DATA_0C="3E13FD13FE1318FD18FE1897A5723A9C" CODING_DATA_0D="B0AA1896960A1361724261C018F80000" CODING_DATA_0E="22010507100C00C81455000000000000" CODING_DATA_0F="42010506E80C00C81455000000000000" CODING_DATA_10="8E010105010001012000000000000000" CODING_DATA_11="00000000100000000000000000000000" CODING_DATA_12="" />
<SG-IDENT SG_ADR="64" COD_INDEX="5" DIAG_INDEX="784" VAR_INDEX="20809" DATUM="16.02.2006" LIEF_NR="4" HW_NR="01" BMW_NR="6943826" SW_NR_MCV="0.16.168" SW_NR_FSV="6.13.20" SW_NR_OSV="3.2.4" SW_NR_RES="0.0.0" IDENT_FORMAT="30" />
<SG-AIF VIN_7="DS87656" ZB_NR="6943826" DATUM="10.09.2007" ANZAHL_PROG="1" ANZ_FREI="1" AIF_SW_NR="" AIF_BEHOERDEN_NR="" AIF_HAENDLER_NR="011111" TESTER_TYPE="31" TESTER_SERIENNUMMER="32333435" KM_STAND="00" AIF_FORMAT="18" FLASH_LIMIT="0" />
<SG_GATEWAY IsGateway="1" SubBusEcuAddressList="39,67,76,77,78,79,105,106,10 7,109,110" RoutingStateDefault="1" />
  • <StateDiagram start_subState="OperatingMode">
  • <DefaultTransitions>
<Transition request="Read_VIN_17" succeeding_state="this" responseType="positive" value="" />
<Transition request="WriteVIN_17" succeeding_state="this" responseType="positive" value="" />
<Transition request="ClearDTCShadowMemory" succeeding_state="this" responseType="positive" value="" />
<Transition request="ReadManufacturerData" succeeding_state="this" responseType="positive" value="" />
<Transition request="WriteManufacturerData" succeeding_state="this" responseType="positive" value="" />
<Transition request="ReadTestStamp" succeeding_state="this" responseType="positive" value="" />
<Transition request="WriteTestStamp" succeeding_state="this" responseType="positive" value="" />
<Transition request="ReadVehicleOrder" succeeding_state="this" responseType="positive" value="" />
<Transition request="WriteVehicleOrder" succeeding_state="this" responseType="positive" value="" />
<Transition request="Status_CBS_VERSION" succeeding_state="this" responseType="positive" value="" />
</DefaultTransitions>
  • <MainState MainStateID="DiagnosticMode" DefaultProgrammierStatus="01">
<Transition request="ECUreset" succeeding_state="OperatingMode" responseType="positive" value="" />
- <SubState ID="OperatingMode" ProgrammierStatus="01">
<Transition request="RequestRandomNumberForAuthentication" succeeding_state="AuthenticationRequested" responseType="positive" value="" />
</SubState>
</MainState>
  • <MainState MainStateID="OperatingModeDefect" DefaultProgrammierStatus="01">
<Transition request="ECUreset" succeeding_state="this" responseType="positive" value="" />
- <SubState ID="OperatingModeDefectInitial" ProgrammierStatus="01" RoutingState="0">
<Transition request="RequestRandomNumberForAuthentication" succeeding_state="OperatingMode" responseType="positive" value="" />
<Transition request="EcuReset" succeeding_state="OperatingMode" responseType="positive" value="" />
</SubState>
</MainState>
</StateDiagram>
</SG>
</SG-LIST>
also
- <EcuList Interface="IFH" DiagnosticProtocol="KWP2000" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="EcuList.xsd" ModelSeries="E66" ModelSeriesGroup="E65">
<Ecu EcuDataFilePath=".\SG\ZGM_E65.xml" />
<Ecu EcuDataFilePath=".\SG\SGM_60_2.xml" />
<Ecu EcuDataFilePath=".\SG\SZL.xml" />
<Ecu EcuDataFilePath=".\SG\SASL.xml" />
<Ecu EcuDataFilePath=".\SG\SASR.xml" />
<Ecu EcuDataFilePath=".\SG\STVL.xml" />
<Ecu EcuDataFilePath=".\SG\STVR.xml" />
<Ecu EcuDataFilePath=".\SG\SSFA.xml" />
<Ecu EcuDataFilePath=".\SG\SSBF.xml" />
<Ecu EcuDataFilePath=".\SG\SBSL.xml" />
<Ecu EcuDataFilePath=".\SG\SBSR.xml" />
<Ecu EcuDataFilePath=".\SG\SSH.xml" />
<Ecu EcuDataFilePath=".\SG\SFZ.xml" />
<Ecu EcuDataFilePath=".\SG\MSV70.xml" />
<Ecu EcuDataFilePath=".\SG\GS19B.xml" />
<Ecu EcuDataFilePath=".\SG\DSC_E65.xml" />
<Ecu EcuDataFilePath=".\SG\EMF_E65.xml" />
<Ecu EcuDataFilePath=".\SG\TELE60_2.xml" />
<Ecu EcuDataFilePath=".\SG\EHC_E65.xml" />
<Ecu EcuDataFilePath=".\SG\NAV_E65.xml" />
<Ecu EcuDataFilePath=".\SG\CDC_E65.xml" />
<Ecu EcuDataFilePath=".\SG\ASK_E65.xml" />
<Ecu EcuDataFilePath=".\SG\CAS.xml" />
<Ecu EcuDataFilePath=".\SG\CIM_2.xml" />
<Ecu EcuDataFilePath=".\SG\POW_65_3.xml" />
<Ecu EcuDataFilePath=".\SG\SD_KWP.xml" />
<Ecu EcuDataFilePath=".\SG\RLS_E65.xml" />
<Ecu EcuDataFilePath=".\SG\WIM_E65.xml" />
<Ecu EcuDataFilePath=".\SG\ANT_E65.xml" />
<Ecu EcuDataFilePath=".\SG\VID_E65.xml" />
<Ecu EcuDataFilePath=".\SG\TMF_E65.xml" />
<Ecu EcuDataFilePath=".\SG\TMB_E65.xml" />
<Ecu EcuDataFilePath=".\SG\TMFHE65.xml" />
<Ecu EcuDataFilePath=".\SG\TMBHE65.xml" />
<Ecu EcuDataFilePath=".\SG\FLA_65.xml" />
<Ecu EcuDataFilePath=".\SG\KOMB65_2.xml" />
<Ecu EcuDataFilePath=".\SG\MC_GW.xml" />
<Ecu EcuDataFilePath=".\SG\MMI_GT.xml" />
<Ecu EcuDataFilePath=".\SG\PDC_65_2.xml" />
<Ecu EcuDataFilePath=".\SG\BZM_E65.xml" />
<Ecu EcuDataFilePath=".\SG\ZBE_65.xml" />
<Ecu EcuDataFilePath=".\SG\FAS_PLX.xml" />
<Ecu EcuDataFilePath=".\SG\BFS_PLX.xml" />
<Ecu EcuDataFilePath=".\SG\LM_AHL.xml" />
<Ecu EcuDataFilePath=".\SG\IHKA65.xml" />
- <Fingerprint>
<VehicleOrder>E66#0306*HN21%0475&U6NB$220$261$2BK$ 358$403$415$416$423$428$430$431$437$441$442$459$50 8$521$524$534$548$5AC$601$609$633$672$691$698$822$ 823$845$850$853$861$864$880$887$8SM$8SX$925$956$98 3$9AA-LEDE</VehicleOrder>
<IntegrationLevel>E065-15-07-500</IntegrationLevel>
<Vin7>DS87656</Vin7>
<Vin17>WBAHN21057DS87656</Vin17>
- <EcuDataList>
<EcuData DiagnoseAdresse="0" SerialNumber="000673475" ZusammenbauNummer="9314363" HardwareSternNummer="9314363" CodierIndex="0" />
<EcuData DiagnoseAdresse="1" SerialNumber="0000A46C3" ZusammenbauNummer="9149936" HardwareSternNummer="9149936" CodierIndex="13" />
<EcuData DiagnoseAdresse="2" SerialNumber="0FFFFFFFF" ZusammenbauNummer="9289173" HardwareSternNummer="9289173" CodierIndex="11" />
<EcuData DiagnoseAdresse="3" SerialNumber="032593951" ZusammenbauNummer="6970886" HardwareSternNummer="6970886" CodierIndex="10" />
<EcuData DiagnoseAdresse="4" SerialNumber="036365A51" ZusammenbauNummer="6970888" HardwareSternNummer="6970888" CodierIndex="10" />
<EcuData DiagnoseAdresse="5" SerialNumber="060410228" ZusammenbauNummer="6970906" HardwareSternNummer="6970906" CodierIndex="10" />
<EcuData DiagnoseAdresse="6" SerialNumber="060410560" ZusammenbauNummer="6970908" HardwareSternNummer="6970908" CodierIndex="10" />
<EcuData DiagnoseAdresse="7" SerialNumber="0000199E9" ZusammenbauNummer="6970901" HardwareSternNummer="6970901" CodierIndex="11" />
<EcuData DiagnoseAdresse="8" SerialNumber="0000583C3" ZusammenbauNummer="6970899" HardwareSternNummer="6970899" CodierIndex="11" />
<EcuData DiagnoseAdresse="9" SerialNumber="033314B58" ZusammenbauNummer="6970890" HardwareSternNummer="6970890" CodierIndex="10" />
<EcuData DiagnoseAdresse="10" SerialNumber="032453051" ZusammenbauNummer="6970895" HardwareSternNummer="6970895" CodierIndex="11" />
<EcuData DiagnoseAdresse="13" SerialNumber="000018383" ZusammenbauNummer="6970904" HardwareSternNummer="6970904" CodierIndex="11" />
<EcuData DiagnoseAdresse="14" SerialNumber="033455330" ZusammenbauNummer="6970889" HardwareSternNummer="6970889" CodierIndex="9" />
<EcuData DiagnoseAdresse="18" SerialNumber="608301128" ZusammenbauNummer="7581264" HardwareSternNummer="7577968" CodierIndex="3" />
<EcuData DiagnoseAdresse="24" SerialNumber="921802668" ZusammenbauNummer="7546524" HardwareSternNummer="7556039" CodierIndex="2" />
<EcuData DiagnoseAdresse="41" SerialNumber="" ZusammenbauNummer="6855554" />
<EcuData DiagnoseAdresse="42" SerialNumber="601021968" ZusammenbauNummer="6769700" HardwareSternNummer="6769700" CodierIndex="7" />
<EcuData DiagnoseAdresse="54" SerialNumber="EM0001725" ZusammenbauNummer="9138168" HardwareSternNummer="9138168" CodierIndex="8" />
<EcuData DiagnoseAdresse="56" SerialNumber="000076022" ZusammenbauNummer="6784314" HardwareSternNummer="6784314" CodierIndex="17" />
<EcuData DiagnoseAdresse="59" SerialNumber="000213425" ZusammenbauNummer="9195222" CodierIndex="4" />
<EcuData DiagnoseAdresse="60" SerialNumber="600266861" ZusammenbauNummer="9133082" HardwareSternNummer="9133082" CodierIndex="0" />
<EcuData DiagnoseAdresse="63" SerialNumber="607589469" ZusammenbauNummer="9150992" HardwareSternNummer="9150992" CodierIndex="5" />
<EcuData DiagnoseAdresse="64" SerialNumber="000000001" ZusammenbauNummer="6943826" HardwareSternNummer="6943826" CodierIndex="5" />
<EcuData DiagnoseAdresse="66" SerialNumber="000189054" ZusammenbauNummer="6788716" HardwareSternNummer="6788716" CodierIndex="4" />
<EcuData DiagnoseAdresse="67" SerialNumber="000564143" ZusammenbauNummer="9132581" HardwareSternNummer="9132581" CodierIndex="5" />
<EcuData DiagnoseAdresse="68" SerialNumber="000000001" ZusammenbauNummer="9137056" HardwareSternNummer="9137056" CodierIndex="7" />
<EcuData DiagnoseAdresse="69" SerialNumber="006062320" ZusammenbauNummer="9120309" HardwareSternNummer="9120309" CodierIndex="6" />
<EcuData DiagnoseAdresse="70" SerialNumber="000000000" ZusammenbauNummer="6976728" HardwareSternNummer="6976728" CodierIndex="3" />
<EcuData DiagnoseAdresse="71" SerialNumber="001462195" ZusammenbauNummer="9145422" HardwareSternNummer="9145422" CodierIndex="3" />
<EcuData DiagnoseAdresse="75" SerialNumber="000001668" ZusammenbauNummer="9179581" HardwareSternNummer="9179581" CodierIndex="0" />
<EcuData DiagnoseAdresse="76" SerialNumber="019002341" ZusammenbauNummer="6964141" HardwareSternNummer="6964141" CodierIndex="5" />
<EcuData DiagnoseAdresse="77" SerialNumber="019002341" ZusammenbauNummer="6964139" HardwareSternNummer="6964139" CodierIndex="5" />
<EcuData DiagnoseAdresse="78" SerialNumber="019002341" ZusammenbauNummer="6964142" HardwareSternNummer="6964142" CodierIndex="5" />
<EcuData DiagnoseAdresse="79" SerialNumber="019002341" ZusammenbauNummer="6964140" HardwareSternNummer="6964140" CodierIndex="5" />
<EcuData DiagnoseAdresse="95" SerialNumber="019002341" ZusammenbauNummer="9158876" HardwareSternNummer="9158876" CodierIndex="5" />
<EcuData DiagnoseAdresse="96" SerialNumber="000000353" ZusammenbauNummer="9140816" HardwareSternNummer="9140819" CodierIndex="6" />
<EcuData DiagnoseAdresse="98" SerialNumber="067563270" ZusammenbauNummer="9149995" HardwareSternNummer="9149996" CodierIndex="0" />
<EcuData DiagnoseAdresse="99" SerialNumber="067563270" ZusammenbauNummer="9165211" HardwareSternNummer="9165211" CodierIndex="4" />
<EcuData DiagnoseAdresse="100" SerialNumber="20203630312E383333" ZusammenbauNummer="9145158" HardwareSternNummer="9145158" CodierIndex="2" />
<EcuData DiagnoseAdresse="101" SerialNumber="019002341" ZusammenbauNummer="6989994" HardwareSternNummer="6989994" CodierIndex="0" />
<EcuData DiagnoseAdresse="103" SerialNumber="AA364GF05" ZusammenbauNummer="6980057" HardwareSternNummer="6980057" CodierIndex="0" />
<EcuData DiagnoseAdresse="109" SerialNumber="000042974" ZusammenbauNummer="6927311" HardwareSternNummer="6927311" CodierIndex="16" />
<EcuData DiagnoseAdresse="110" SerialNumber="000043703" ZusammenbauNummer="6927311" HardwareSternNummer="6927311" CodierIndex="16" />
<EcuData DiagnoseAdresse="112" SerialNumber="000010824" ZusammenbauNummer="9116260" HardwareSternNummer="9116260" CodierIndex="33" />
<EcuData DiagnoseAdresse="120" SerialNumber="000247498" ZusammenbauNummer="6981405" HardwareSternNummer="6981405" CodierIndex="5" />
</EcuDataList>
<HashValue>76bfa91db8e9cb680b890b1bbf31368</HashValue>
</Fingerprint>
</EcuList>
i hope this data can help
Discussion Starter · #5 ·
i have posted there
if any one can help i cant move the car
1 - 6 of 6 Posts
