Just took it out for a short spin afterwards. It seemed to shift a little faster - like when it was newer. Will update at 1K, 5K, etc. That was one thing I did notice, there were very little long term follow-ups from people that have changed their fluid. My BMW owners service manual calls for changing the ATF at 100K. The dealership now uses Dexron VI. Either this is what is good for the tranny or there is a massive corporate wide BMW scam to sell trannys. I will offer a couple of suggestions for those people that are going to do it. Go to Home Depot and get the small concrete mixing tub - makes the perfect catch pan for everything. From reading on this forum I bought an 8' 2"x10" and cut it into four 2' sections. Drove the care up on them and used the tub for re-doing the cooling system - big enough to catch everything without having to move it and the 2" lift gives enough clearance. For the tranny you can drop the whole pan into it and not spill on the floor - then pour into your measuring container. I know I will get criticized for the next suggestion but I have been doing it for longer than most of the members are old. Get a can of K&W Copper Coat or the Permatex equivalent. Lay your gasket on some newspaper and spray one side. Let it dry for about two minutes and stick that side to the clean pan. You won't have any problems trying to get the gasket holes aligned when putting the pan back on - this is not needed when using a steel gasket. Will post more later.
