1 - 20 of 112 Posts
· Registered
Yesterday took my car to car wash(hand wash) and then when I went home, I started the first polishing job on my baby.
With the zaino applicator, I applied z1 on the whole car and then when I finished, I started applying Z2.
When I am done with Z2, I started using a 100% made in usa towel to take off the wax BUT I COULDNT TAKE IT OFF?!?!?!!
Its like the wax is stuck on the paint and I had to scrub very hard to get it off. I spent like 2 hours but still the wax is stucked on the paint. What have I done to my baby??? :bawling: :bawling: :bawling:
Help this rookie plzzzzzzzzzzzz!!!!
· Registered
Discussion Starter · #5 ·
right after i finished with the whole car, oh no, i guess i didnt wait long enuf....:cry: :cry: :cry:
Any remedy???
· The Original Dr. Phil
Sounds like a question for Dr. Alee:dunno: Here is an older link to his pointers Z by Alee But it does not talk about how to fix your problem:(
You could switch to Blitz like your neighbor Vexed;) j/k
Hopefully some Zaino users will com to your help.
· Ex-Dictator
First time with Zaino ? Probably you used 'too' much. The magic word is 'very thin coats'. I had the same problem at first.
If it still won't come off, use a damp towel, wipe it off and apply it again very thin coats ( I mean very thin)
Damp the cotton applicators with water or squirt a few drops Z6 and put Z2 or Z5 on it, spread it with your finger, and ready to go.
Humidity is an enemy of Zaino, it takes ages to cure if the weather is humid. If you have the chance to leave the car under the sun, first apply Zaino and leave it under the sun. According to Sal Zaino, it takes about 20-30 minutes to cure under the sun.
BTW, you can use Zaino under the sun.
· Registered
Discussion Starter · #9 · (Edited)
Yes, first time :(
And yes I just tried again to buff it off, a lot of it came off but everyone can tell I had a BAD WAX DAY!!!! A lot of swirl marks and residue :cry: :cry:
Also I noticed a lot of scratch marks, I probably scrub too hard :cry: :cry:
And its raining today :bawling: :bawling: :bawling:
· Ex-Dictator
bimmee said:
Yes, first time :(
And yes I just tried again to buff it off, it wont come off :cry: :cry:
Good, stop crying now :D
Do what I wrote above.
Don't forget , thin coats
· Registered
Discussion Starter · #11 ·
Cant help :bawling: , my baby is only less than 2 weeks old.
So, please bear with this rookie, can i ask how much(just about, like how many pea size drops) is enough for say the hood?
Thanks for the advice, cant do anything until tonite :(
· Ex-Dictator
With one pad you should be able to do the hood easily. (even that maybe not thin enough) It takes a bit practice, but don't give up. As I said before, damp the applicator with Z6 and you'll be fine.
BTW, if you can find foam wax applicators , buy them. They are much more effective to use.
· Registered
Discussion Starter · #13 ·
I tell ya, I was so angry at myself last nite I told myself I will just take it to the carwash. Those machines will do less damage then what I did.... scratch marks, swirl marks, residue marks.......
When you said one pad, ummmm, how much is that exactly? :confused: :confused: Dont want to do it wroong again..
· Ex-Dictator
Take the cotton applicator, squirt a little Z6 , and squirt a big 'X' in the middle. That should be enough.
· Registered
Discussion Starter · #15 ·
Ok, I can understand that :p
So the same amount for Z1 as well?
Thanks sooooooooooo much Alex
· Registered
Discussion Starter · #17 ·
Alex Baumann said:
Yep, thin coats for Z1 as well.
I know you can do it! :D
Thanks. Really appreciate it, will let you know, when i do it again..if that happens....... :p
· Ex-Dictator
in_d_haus said:
OR.... switch to a Carnauba wax product 'cuz Zaino is a PITA! :D
Try Griots Best of Show or Carnauba wax... it's da bomb baby! :thumb: :D
Who let you in here? :D I think Rip forgot to close the door :bigpimp:
1 - 20 of 112 Posts
