1 - 7 of 7 Posts
BMW Nuthead
Need Help, I Threw A 19 And 44 Fault Code..the 44 I Knew Was Coming But The 19 Was A Surprise...there Are Several Different Tables In The Manual It Is Either A 02 Sensor Or A Cylinder #1 Coil Pak, How Do You Know Which Table To Use In The Owners Manual To Find The Specific Code Thanks Guys My Car Has 66k Miles On It
BMW Nuthead
Discussion Starter · #2 ·
Oh Yeah The Car Runs Very Well, Better Than Ever....so If Was A Faulty Coil Pack I Would Probably Notice A Rough Idle
Get left...Go Fast
the first number that pops up is the table...then the fault...on a side note...why do you capitalize the first letter of every word ? is it just a habit ?
Here's the drill:
put the key in and turn it to pos 2 (do not start)
put the peake tool on and press the button. (when it reads Fc)
1st Numbers (and/pr letter) is the table,
the ones that follow are the faults
my peake manual states quite clearly the first number is not a code, but rather gives the table you should refer to. i just ran my tool last night and also got 19 (table), then 12 (code).
BMW Nuthead
Discussion Starter · #5 ·
i called peake thanks guys, when i type I use all caps because I leave the lock on due to the DOSS based system that I use for the dealership...so now I have to find out why the purge valve is not working
Get left...Go Fast
Thanx for the explanation Brian...:thumbup:
1 - 7 of 7 Posts
