Using ESYS --- Issues and Solutions
100K views 194 replies 48 participants last post by  BimmerGuy7
#1 · (Edited)
List of problems you may encounter and solutions to fix them
1) Problem:
When i choose "Read Coding Data" I get this error:
Transaktions-Report: Aktion: Codierdaten lesen
CAS [40] [C271460]
readCPS o.k.
cafd_0000000f-005_022_007 Fehler:
File for "cafd_0000000f-005_022_007" not found! [C012]
Solution:
Make Sure you have copied the SWE contents from PSDZData/SWE to C:/EsysData/SWE (You should have it in both the locations)
2) Problem:
I open E-Sys and when I hit connect get the pop up which has my VIN next to that radio buttion, but nothing shows up in the Target box.
Solution:
More than likely the "dist" folders missing from your installation. The folders should be empty, but they need to be there:
and make sure the folder names/directory is correct.
http://www.bimmerfest.com/forums/sho...postcount=1453
3) Problem
Ethernet Connection Problems
Solution:
Disconnect and Reconnect
#154 ·
Ok, good luck. And if you don't have Ethernet on OBD Port, you will need to connect to Ethernet at back of NBT.
#159 ·
And you are connecting as follows?
E-Sys Launcher Car Series = F013
E-Sys Connection Target = F010
#162 ·
Coding for G series
Has there been any success in coding the G series?
I've used E-SYS launcher v3.26.1. I was able to see some of the modules and access parameters, trying to code the Video In Motion. The parameters would save and the FDL coding for that module would complete successfully but the DVD or Video in Motion would not work.
THe other modules i'm trying to change are folding mirrors and other simple stuff.
Has anyone been able to code a 2016 7 series? Do I need some updates or are we still waiting on files to be released?
Thanks.
#163 ·
Thanks.
You need to use E-Sys Launcher Pro, not Premium, as TokenMaster has not yet added G-Series support to Premium version.
But even then, Video-In-Motion coding is not working in G-Series NBT2 EVO.
#168 ·
Thanks Shawn.
I had also tested the SPEEDLOCK_SPEEDVALUE and didn't get it to work.
Any good source for the E-SYS launcher PRO download? It's been a while since I obtained my software.
Just Email Developer TokenMaster at fxxtokenmaster@gmail.com.
#169 ·
Is it recommended to uninstall older versions of e-sys and install the newer version or can I install the newer right over top of the old installation? When installing the new version do I have to create a new token with a 48 hour waiting period? I had coded my car, but the dealer flashed the latest on it. Updated data files to 59.4 but my e-sys version is to old. Giving me some error when coding the car. Curious if I can install the latest e-sys on top of the older one.
Thanks.
#170 ·
Normally, you update only what needs updating, which in most cases is the psdzdata files only, and that is simply a matter of deleting existing psdzdata folder and replacing it with new one. But latest psdzdata version at some point will necessitate a newer version of E-Sys. At that point, you should uninstall old E-Sys and reinstall new one. This should have no impact on existing token-solution assuming you are using E-Sys Launcher. Lastly, update E-Sys launcher only as needed (bug fixes or feature additions). You can install it over existing version, and it should have no impact on existing token-solution.
#176 ·
Hi
after flash ZGW2 all ok and tried flash AAG give me error
TAL execution started.
VCM Update: VCM-Update is deactivated. VCM will not be updated. [C197]
ExecutionID=2017/01/08-17:09:45.766
[AAG - 71] - [Exception - AAG - 71] job failed with negative response error:
code: repeat job
description: Service RD returned a negative response with response code requestOutOfRange; ECU: AAG_71_ETHERNET
severity: ERROR
code: repeat job
severity: ERROR
[] - [Exception - AAG - 71] job failed with negative response error:
code: repeat job
severity: ERROR
TAL-Execution finished with status: "FinishedWithError". [C207]
TAL execution finished. Duration: "2min 7s". [C206]
Any help, please...
#177 ·
Guys,
I have 2011 535i F10 US and ZGW serach doesn't show up VIN number. I have no idea why, I have no firewalls active or anything. ENET cable is fine, tested on different BMW.
Can anyone tell me what is the other way to code CIC and KOMBI? Taking into consideration that ZGW search is blank and ESYS connection via VIN is grey can I somehow connect to HU_CIC and KOMBI directly? I know that CIC has IP which I can use, but is the same possibility to connect with KOMBI?
If yes then please tell me what is the IP of these two modules.
Thanks in advance.
#178 ·
You cannot code Kombi direct by IP. You need to try another laptop. Some windows networking setups just flat out refuse to work.
#179 ·
Thanks Shawn.
My problem is that I have this issue only with that one F10, ZGW is easily recognized with other Fxx cars.
I checked the errors via ICOM and ISTA-D and all is fine, however I have a problem to connect with E-SYS via ICOM 169.254.92.38:50160 - it gives me [G188] error (ICOM is reserved).
So the weird thing is that I can diagnose the car but can't connect with E-SYS to code. How it is even possible? It works in different way?
From the other side ENET doesn't recognize car at all (no IP) in ZGW search or E_SYS.
Any suggestions? Maybe I should disconnect battery for some time to see if this works?
Thanks.
#180 ·
ENET should be getting IP Address. I have no idea what is up with this ZGW. Maybe it can be initialized with Tool32 ZGW.prg.
#181 ·
Hello,
I'm trying to code an i8, I012 chassis, but I'm getting an Ethernet doesn't map to that item error whenever I try to edit the ASCM2 and BDC Body Module. can anyone offer any insight?
I was using esys 3.28.1 with PSdZData 3.60.3. I wasn't able to edit any of the modules in ASCM2 and BDC_Body. All the others I was able to access, edit, save and see results. However, for some reason I can't edit the ASCM2 and BDC_Body.
I get the following errors when I try to edit.
17-05-05 19:40:10,385 [INFO] [] com.bmw.prodias.collections.mcd.AbstractNamedCollection: provided name BDC_GW_10_ETHERNET doesn't map to an item [AWT-EventQueue-0]
17-05-05 19:40:10,385 [TRACE] [] com.bmw.psdz.vehicle.connection.wrapper.ConfiguredDProject: openLink for link BDC_GW_10_ETHERNET failed with MCDError Severity: 2051, Error Code: 49184, Description: Object with name not found, Vendor Code: 3, Vendor Description: provided name BDC_GW_10_ETHERNET doesn't map to an item [AWT-EventQueue-0]
17-05-05 19:40:10,385 [WARN] [] com.bmw.psdz.vehicle.connection.wrapper.ConfiguredDProject: openLink impossible Exception: com.bmw.prodias.exceptions.mcd.ParameterizationException: Code=49184, CodeDescription='Object with name not found', Severity=2051, VendorCode=3, VendorCodeDescription='provided name BDC_GW_10_ETHERNET doesn't map to an item' [AWT-EventQueue-0]
I see the similar code of 'ETHERNET doesn't map to an item' for both ASCM2 and BDC Body.
Can anyone provide insight? I get the same error when I updated the PSdZData to 3.61.3.002.
#182 ·
"doesn't map to an item" means incorrect E-Sys Launcher Car Series or Incorrect E-Sys Connection Target,
#188 ·
Anyone know if this is possible to get around? I get it on both blflash and swdeploy.
[ZGW2 - 10] - [Exception - ZGW2 - 10] job failed with negative response error:
code: repeat job
description: error in routineControlEraseMemoryIndicatedErasing: expected return code "correct result" but got "incorrectResult"; ECU: ZGW2_10_ETHERNET
severity: ERROR
#189 ·
code: repeat job
severity: ERROR
#191 ·
I have spent countless hours trying to get E-sys to work. I am now on a laptop with Win7, with E-sys 3.30 loaded and the 4.27 pzdata file. I can get all the way to Reading the FDL I want to code (ASD to off) and then when I try to edit, I get an error [C027], something about java pointers? Can anyone help? Also there is an error occasionally asking for an EST file. Can someone PM me the file/token? Thanks
#193 ·
I was reading the code on my car earlier. I had an uncommited code but I exited esys without committing the code. When I try and reconnect I get the following error.
I then have to enter my model and shipment date which was being read earlier and I get the following error when I try to read the FO.
The car works fine other than my inability to connect to the ECUs.
Any ideas?
#194 ·
Any ideas?
If using an ENET Cable, in the "Open Connection" window under "Interface" select "Connection via VIN", not Gateway URL
In the "Open Connection" window under "vehicle-specific parameter (optional)" select "Series, I-Step Shipment", and leave the two Dropdown boxes blank. Do NOT select "Read parameters from VCM".
After connection, use Read (ECU), not Read (VCM).
  • Like
Reactions: BimmerGuy7
