Can you take a picture? I would like to see the clutch arm assembly that attaches to the master cylinder. Maybe someone here can figure out a way to physically defeat the clutch starter switch.Dirtboy said:
Can you take a picture? I would like to see the clutch arm assembly that attaches to the master cylinder. Maybe someone here can figure out a way to physically defeat the clutch starter switch.Dirtboy said:anyone out there have a 2002 e46 with manual tranny with UUC clutch stop installed. the switch on the '02 models is incoporated into the master clutch cylinder. the sensor mounted on the cylinder has four wires connected to it. which one's should have contact to start the car? anybody have access to wire diagrams for the '02 models?
Pre ~Oct 2000 prodcution E46s are as pictured at BMW330Ci.com. But after that, as you learned, there is no switch.Dirtboy said:nope, sorry don't have a camera. what it looks like- the master cylinder has a connector with 4 wires on it (forgot the colors), and there's no separate switch for the starter safety switch. i think bmw must have changed the setup cuz www.bmw330ci.com has a DIY for this and it shows the clutch switch separate from the cylinder. i was just wondering if i could just hook a push button switch in parallel with the wires there. but i need to know which wires to hook up...:dunno:
Knowing Rob and UUC's business practices, they'll be free.Dirtboy said:think the fix will be free for those of us who have the clutch stop already? or at least at a ruduced price? :thumb:
I'm not entirely sure on that... I know that UUC typically posts a free DIY guide for this sort of thing, but... Given the level of difficulty that is involved in this, i.e. modifying the clutch master cylinder, I have to wonder.The HACK said:
I am curious as to what you had to trim? Mine works with no modification.Nat Brown said:I've got the UUC Big Boy on my 2002 330i. It had to be modified with a hack saw to work. Start trimming it back until you get engagement. Works great now.
--gary
I trimmed some of the threads, about 3-4 mm, in order to get clutch engagement. Otherwise I couldn't get the switch to trip.ERK said:
I have it adjusted right at the point where the start switch is hit. Sometimes I even have to push the clutch pedal a little firmly against the Big Boy to get the switch to trip. I only have about 3/4" of travel past the engagement point.
