The A pillar cover is secured by 3 screws covered up by a long, rectangular shape upholstered cover. The screws are #20 torx screws. Remove those 3 screws and the cover pops right off.
You can secure the wires with wire ties or small clips along the edge of the A pillar. Once you have the cover off, there should be a small opening to slide the wires down through the passenger side vents. You will need to remove the passenger side vent to snake the wires down past the dash board. To remove the side vents, remove the dash trim piece by prying up with a pry bar or taped screw driver from the far right side of the trim, and pull along the bottom edge to release the trim from the clip. That should expose the two screws holding the side vents in. Remove those two screws and the side vent should wiggle free, then you can snake the wires down to the glove compartment.
Disassemble the glove compartment, release the hinge clips by unscrewing the two screws holding the hinge in on the back underneath side of the glove compartment, then remove the two screws holding a canvas strap and a hinge in on the side. There are 4-5 screws holding the entire glove compartment together along the edges. Remove those and the entire glove compartment should drop down allowing you easy access to the glove box, the power supplies behind the glove box, and your wires. The rest should be fairly simple, just identify the proper wires (I can't remember now, but I think it's either yellow/blue or green/blue) and where they're connected to, and splice into the right wire.
Good luck. I hope my instructions make some sense...It's hard without pictures.
