1 - 20 of 41 Posts
just got a Valentine1 and i want to hardwire it, i bought an add a fuse...but can't find a place in the glovebox to ground it...please help
My TARDIS is a BMW
Raffi said:
:stupid: Doesn't Valentine's hardwire kit come with a fuse anyway? :dunno:
Maybe he didn't buy it used and didn't get all the little doodads that come with it?
The V1 comes with hardwire pieces and fuse yes, but his question is where is a place you can ground the wire. I know the glovebox does not over and metal to metal contact all screws are surrounded by plastic enclosures.
My TARDIS is a BMW
We would need to know where he is mounting the V1 to be able to tell him where the closest grounding location is.
My TARDIS is a BMW
330ciPfmcePkg05 said:
what does everyone else do ?
Hardwired to the harnesses above the rear view mirror where the moonroof open/close switches and the UGDO would be installed. I don't have any pictures handy, but do a search for the other V1 threads which have pictures and links to DIY instructions.
King of Rear Clunks
Because the way everybody else does it is half-assed. :D There is a ground comb connector above the fusebox. This is where the rest of the dash components are grounded. You will need a 61 13 1 387 14x (x=0,2 or 4, though I'd recommend 2 for this) to plug into it. Getting to it is a major pain. Also, for a Ron Stygar-like job, you'll want to get a 61 13 0 007 439 or 440 to plug into the back of the glovebox to get a real fusebox connection.
Discussion Starter #11
right below the rear view mirror towards the left of the driver's side
My TARDIS is a BMW
Open the access panel in the roof right above the rear view mirror. There are several small screws in there that are good for grounding. If you are placing the V1 in that locations, why are you wiring it down in the glove box instead of up in the roof?
Premium Member
Where do you plan to mount the V1?
Most mount it up near the top of the windshield (on either side of the rearview mirror) and then snake a wire into the headliner to reach some wire that has switched power.
I know what to tell you for an E39 5-series but I do not know the specifics for an E46.
In the E39, we have a map light and area for the UGDO and sunroof switch. We simply pop those off the headliner and find the correct wire (I forget which one now....see www.bmwtips.com) and use the special little wire connect to tie to the switched power and a ground is readily available there.
My TARDIS is a BMW
Same thing on an E46, all except the 'vert. We did try to wire one up to the harness in the rear view mirror of a 'vert, but it could't power the V1 and we ended up kinda continuously "dialing" Assist.
Assuming he can't find a ground in the glove box odds are he is using add-a-fuse and running wire up along headliner down a pillar into box. I am not sure of a ground junction near the fuse panel.
Kaz, do you need to drop the fuse panel to access this area?
King of Rear Clunks
Yes. In fact, unless you have very small hands or your car's wiring harness was built with a lot of slack, you will have to disconnect the fusebox's hinges. And that's only to get to the big block with all the comb connectors on the inside.
http://www.bimmerfest.com/forums/showthread.php?t=62738
This gives an idea of what's involved, though this discusses how to get to the bus signal comb connector (and done with a halfass contact, not a BMW one).
Kaz that is an outstanding mod. Really impressed but damn! 6 hours!!!!
Hi
If he hardwires it by the moonroof motor, then there are grounding screws there.
1 - 20 of 41 Posts
