My angel eyes stopped running the other day (I am using Daeos Vista harness). I decided to check the voltages to see if a fuse blew or the relay went out. I did some probing and read only 4.88V on the line to the angel eyes. I know it's supposed to be 12V. I popped open the ECU cover to where I tapped the accessory line (red wire with white stripes)...I measured it directly off of the tap from that wire and it read 4.88V (thus eliminating anything down the line...i.e. the harness). Does anyone know what can cause this low voltage reading on the red wire with white stripes in the ECU? Bad fuse? Or worse?
