Hi guys,
Title summarises the issue nicely. My car is a 2006 E92 325i with the 2.5 N52 (Euro spec, UK) at 148k miles. When the car is started cold, I have no funny issues, car has normal power, all is well. If the car is stopped and restarted once the oil reaches around 80 degrees Celsius (176 deg F), the car surges from around 600-700 RPM, up to about 1400, then drops down. Here's a video. Following this, 100% of the time, the car will be utterly gutless below 3500 RPM and lacks power through the rest of the RPM range too.
If you start it while warm a few (2 or 3) times consecutively, it will eventually illuminate the CEL just after surging. I have a Foxwell NT530 which shows the only code to be the infamous 2A82 VANOS intake code. But again, it only does this when started warm. Cold starts are perfect. I wouldn't be too worried about this if it wasn't for my MOT next month. I'm worried that after the garage take it on and off the ramp a few times during the test, the CEL will illuminate and cause it to fail.
Here's a list of work I've done since August last year, when I got the car:
• Brand new genuine VANOS solenoids
• Swapped solenoids, code remains on intake side
• Removed and cleaned VANOS check valves (not replaced)
• Oil and filter flush and change, replaced with Castrol Edge 5W-30 LL (should be approved, but has apparently lost certification, topping up with M variant now)
• Replaced oil filter cap, old one was missing filter cage and VANOS O-ring. Performance improved enormously from this
• Big DISA valve replaced, motor had failed. Small DISA not touched yet, but seems to be working
• Various adaptation resets and relearn procedures, VANOS, Valvetronic, etc
• CCV diaphragm replaced (built into plastic VC, rest of VC untouched)
• Checked ESS connector, no oil in connector or around pins
The oil change was done around 4.5k miles ago, so I'm thinking I will change it again for good measure before the MOT anyway. My suspicion is that it's related to the oil viscosity when warm, but I'm not confident.
I want to do plugs, but I figured this issue is unrelated to plugs seeing as I've actually got a VANOS code. One thing at a time haha
Any help would be much appreciated. I feel like I've ticked off most of the common failure points for VANOS faults, and the warm start thing leads me to believe it's related to the oil viscosity when hot, but I'm hoping someone else knows better. Cheers
