i don't use one touch as it seems to forceful, causing it to eventually self destruct.
You have a point because somehow, mine 'self destructed' when they went too high up in the door (I assume because the glass, being removed, allowed them to).
you need to remove the interior trim...The clips for this should be visible from the inside view of the door with the panel off
Thanks for the advice. It's amazing how little hints and suggestions help move forward.
No matter how much I squeezed with my hands, I just either did not have the finger strength (or I didn't have the technique) to pull up that interior chrome trim.
So I used a screwdriver for leverage, obtaining uneven results.
Here's as detailed a DIY as you can get on removing the inner window trim bar.
Lifting with my fingers just didn't work (for me).
So, I first tried prying the visible part of the trim clip away with a screwdriver:
But all that did was scratch the window clip.
Then, I shoved the screwdriver deeper, and used a spooning motion, to leverage up and out.
The trim budged ever so slightly ... so I moved the screwdriver to below the clip, and leveraged upward.
Finally I was getting some air below the clip ... so I moved to the next clip and leveraged upward similarly with the screwdriver.
After the first two clips, I was able to grab the trim with my hands and pull upward. Much to my surprise, the third clip stayed on the trim. I'm not sure if that's whats supposed to happen though ... but I wasn't stopping at this point ... so I pulled until the trim came off the door.
I noticed the sixth clip was of a different size & shape than the first five ... so I started wondering (belatedly) if I shouldn't have worked from the front forward rather than from the rear frontward ... so that exercise is left for the next person to contemplate.
The good news is that only the inner trim was needed, as I was prior advised, in order to slide the window back inside the door.
QUESTION:
Q: Were the trim clips supposed to stay on the door (as two did) or to come off with the trim (as the other four did)?
EDIT:
This DIY shows how to remove the trim - and they didn't mention it but I can see not all the clips came off with the trim:
EDIT: This video is for the rear window, but it shows another way to release the window trim clips (go to time point 0:45s to 0:55s):
