1 - 8 of 8 Posts
Nuclear engineer
Discussion Starter #4
Do you mean what size is the head of the bolt or the size of the threads? I'm pretty sure it's a 10mm hex head bolt.
Yes those they are 10mm but I didn***8217;t know thread or dept. do you have to know in the coolant pipes the rubber washer and plastic washer do they go on all I was looking for a diagram etc
Nuclear engineer
Gee Zeus! M8x32. 8 mm diameter. 32 mm long. Aluminum. ISO metric threaded fastener.
Doug I think you may be on the wrong car. The bolts I think he's talking about are more than likely a 6 mm diameter, they aren't very big, and I'm pretty sure they are not Aluminum. There should be four shorter bolts and one long bolt that should go where the dowel pin is. What do you mean by rubber and plastic washers?
Nuclear engineer
I’m pretty sure that OPie hasn’t told us enough to guess otherwise. His RIGHT car is near that link if he will look to know and not “think” and “guess”.
Discussion Starter #8
Yes these are ones my three year old was shop inspector on this and he walked off the job with them
1 - 8 of 8 Posts
