Hey Guy, I just bought a 01' 740i last week and brought it back home to start diagnosing multiple issues. Today I connected my Foxwell 630 scanner on the car and went through the codes, as well as the ABS and airbag modules and their respective codes... I'm able to erase the ABS codes but they always come back, but I can't erase the airbag module codes for some reason.
Again, the car is new to me, the front right door card was removed when I got it, as well as the door airbag, which I since reconnected., and hooked the battery back up. I scanned all airbags individually and all are "active" and detected, and seat belts switch are operating normally. It's very possible that the car was neglected and both the ABS module AND the airbag module are bad and need replacement...Or it was in a minor crash and was put back toguether by an amateur who never bothered to chase the warning light situation.
I also remember seing 3 separatre code in the airbag diagnostic section, one of which was a "power supply" code linked to the airbag module. (I can check and report back precisely if need be) So I find it pretty weird that both modules would do that at the same time... Can these modules be linked by a single element, like the BST battery cable, or a blown 40/50amp fuse or something of that nature?
Let me know what you guys think and how I should start to diagnose these issues. Like checking for voltage at both modules I presume...
