The drain from my sunroof is leaking INTO the car, I was trying to find where the drain terminates as it may well be choked near ground level, also does anyone know if the drain is metal tubing or plastic ?
The fronts seem to leak more than the backs. They go out the front and exit above the windshield under the trim. You have to be careful trying to clean them as they rubber tubes come off the metal very easily. If you have to get that keep, clamp or zip tie them down. Have you had the windscreen replaced by chance? These holes often get glued over when this work is done.
