1 - 15 of 15 Posts
I have a 2012 X3 with 17" wheels. Apparently that's not so common, but it is what it is.
Anyway, it's time for new tires again. Last time I did this, I put on these:
245/55R-17 Michelin Primacy MXM4 ZP
They are apparently unavailable now.
Tire Rack has three options, these look like the best alternative:
CINTURATO P7 ALL SEASON RUN FLAT - SIZE: 245/55R17
Is that my best bet? I had heard bad things about Bridgestone Duelers.
I am open to not doing runflats, but don't really have a concern either way. In my experience, nobody has these in stock, so if I do have a flat, I'm looking at buying new tires anyway and not having the use of the car for a couple days, so non-runflats aren't looking so bad.
Ideas?
I had the Pirelli all-weather tires on my wagon, and they had poor steering response, so that I was never satisfied. Now I have the summer P7 Cinturatos, also from Pirelli, and they have very nice steering response. I use Pirelli Soto Zero tires in the winter. The X3 is a little heavier with more ground clearance than my F31, so that my experience is not exactly comparable to your case.
In between the first Pirellis and my present ones I had high performance Continental tires that were too harsh and too noisy and also wore down too quickly. I found a telephone call to Tire Rack very helpful. Good luck in finding tires that you like!
If your wedded to run-flat tires and no 17's are available, why not by a set of 18" wheels and take your pick of various brands? There are plenty of reconditioned X3 and X5 wheels (both will fit your car) on ebay.
Discussion Starter · #4 ·
I am open to creative suggestions, and not wedded to run-flats. This is already a ~$1000 undertaking, so I wasn't necessarily looking at ways to double that (i.e. winter/summer tires, or new rims). I could spend the extra money if it really was the best answer, but would prefer not to.
I bought a set of General winter tire AND wheels for my 2016 X3 (sized 225/60-17) and spent no where near a $1000 for the entire setup. Not sure where you buying your tires, but Tirerack lists two dozen tires in 225/60-17 and many are around $100 each. BTW, my owner's manual lists 225/60-17 as an acceptable size for the 2016 X3. Granted there not as wide as 245's, but the difference is not easily noticed and you're concerned about cost.
Discussion Starter · #6 ·
OK, I will look into that, that's a creative suggestion. I was quoting approximate prices for tires considered to be valid for my vehicle, and none of those are close to $100/tire.
My owner's manual does not say 225 60r17 is an acceptable tire for the vehicle, and I've never seen any online tire size lookup (at a tire vendor or the BMW web site) list that as an acceptable tire size, but perhaps it's an option. Thanks for the tip!
Discussion Starter · #7 ·
OK tire fans, so armed with the suggestion to change sizes, today's best idea is a Bridgestone Driveguard 235/60r17. This is still a runflat, just slightly larger and thinner than the 245/55r17s spec'd for the car. They are at TireRack for $138 plus various fees for delivery and then installation. So this looks like my go-to plan unless anybody has any other inspiration.
just few weeks back had new CINTURATO P7 ALL SEASON RUN FLAT - SIZE: 245/55R17 tires, previously had Bridgestone Duelers but less then 15K miles 2 of the tires worn out completely on the edges. when asked the tiretrack SA who suggested to go for CINTURATO P7 ALL SEASON RUN FLAT
Discussion Starter · #11 ·
225/60r17 would be the alternative correct size to your 245/55r17. I use that size for my winter tires vs my 18" for summer. Check tire comparison Tool:
https://tiresize.com/calculator
It is the correct tire diameter, sidewall, circumference, and revolutions to not affect your speedometer.
Understood. The Tirerack agent claimed that the 0.4" difference in width made the 235 a better choice for the application, despite the 1.x% speedometer difference. You may disagree.
Who, me?
We replaced our Bridgestone Duelers with another set of Bridgestone Duelers (runflats). That's been a couple of years ago. On a 2011 with that same size.
I joined Costco just to buy the tires from them. They were that much cheaper. I think I was out for about $900, including the $55 membership.
1 - 15 of 15 Posts
