JG said:I noticed last night that upon starting the engine - the bi-xenons do some kind of up, down beam adjustment. Any idea what that is?
Also I noticed a small bit of condensation on the outer clear cover at the bulb location.
Is that just because of the heat differential between the colder air on the exterior?
Ack said:The condensation usually means you have a small hole/tear or a bad seal somewhere in the headlight cover. For me, the rubber boot that is located where the bulb connects had a small tear in it. I took the cover off, dried it out and then used some silicon gel on the tear and the problem was fixed.
philippek said:They put their left foot in, and put their right foot out...
It's just their auto-leveling adjustment. Looks kewl. Wish they would do a side-to-side adjustment too...that would be badazzzz.
