1 - 14 of 14 Posts
-The Mouth-
Ok I have a 2002 325i with Xenon. My xenons come on with day time runninglights and manually with the switch. but the inside lights next to the xenon lense never come on. Are they supposed to be city lights or what? and how do I turn them on???
superwagon pilot
'17 991.2C, '19 e450 wagon, 11 135iC, 09 x3
If you have an '02 with Bi-Xenon, these should be your DRLs, IF you had the dealer turn on DRLs in your car/key program. If your just turning your lights on during the day, and using your Xenons, then your not really using DRLs at all.
The Inner lights also function as your highbeams, when you flash the high beams quickly, since the Xenons can't react and refocus that quickly.:dunno:
atyclb said:
incorrect. Flashing your brights uses the halogens
Hmmm... That's actually something I didn't check out on my former M3... I mean, when you have Bi-xenons, the xenon headlight may be used when flashing... At least when the low beams are on, no? :dunno:
In Mod Heaven
No. Even with the xenons on low beam, the halogens will flash when you pull back on the stalk.
I actually checked on this. the dtr lights are the inside halogens
when you flash someone by pulling back on the arm, it uses the inside halogen lights
when you use the switch, normal lights = xennon lights = xennons brights.
-The Mouth-
Discussion Starter · #10 ·
Ok I think I figured it out: after much testing
IF DTRL are activated: inside halogens will come on during the day and will flash if stalk is pulled towards you.
If DTRL are NOT activated they will still flash if stalk is pulled towards you.
Xenons come on whn headlight switch is activated. Xenons intensify as highbeams when stalk is pushed away from you.
FINAL QUESTION:
If DTRL are activted do both the xenons AND the inside halogens come on at night when the headlight switch is activated???
3seriesbimmer said:
FINAL QUESTION:
Nope... Halogens (inside) will turn off when low beams are on.
-The Mouth-
Discussion Starter · #13 ·
so if DRL are activated th innner lights will come on when the car is turned on even if the headlight switch is in the off position right?
because the only way I can get my innner lights to come on day or night is to pull the stalk towards me.
does this mean my DTRL are not activated.
(I didnt get to choose key and memory options)
yes yes yes
1 - 14 of 14 Posts
